Light Field Segmentation Using a Ray-Based Graph Structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we introduce a novel graph representation for interactive light eld segmentation using Markov Random Field (MRF). The greatest barrier to the adoption of MRF for light eld processing is the large volume of input data. The proposed graph structure exploits the redundancy in the ray space in order to reduce the graph size, decreasing the running time of MRF-based optimisation tasks. Concepts of free rays and ray bundles with corresponding neighbourhood relationships are de- ned to construct the simpli ed graph-based light eld representation. We then propose a light eld interactive segmentation algorithm using graph-cuts based on such ray space graph structure, that guarantees the segmentation consistency across all views. Our experiments with several datasets show results that are very close to the ground truth, competing with state of the art light eld segmentation methods in terms of accuracy and with a signi cantly lower complexity. They also show that our method performs well on both densely and sparsely sampled light fields.
LF_segmentation-accepted.pdf (10.53 Mo) Télécharger le fichier
hal-01388965 , version 1 (15-11-2016)
  • HAL Id : hal-01388965 , version 1
Matthieu Hog, Neus Sabater, Christine Guillemot. Light Field Segmentation Using a Ray-Based Graph Structure. European Conference on Computer Vision - ECCV, Oct 2016, Amsterdam, Netherlands. pp.16. ⟨hal-01388965⟩
322 Consultations
231 Téléchargements
