Not seeing the crime for the cameras?, Communications of the ACM, vol.53, issue.2, pp.22-25, 2010. ,
DOI : 10.1145/1646353.1646363
Face hallucination VIA sparse coding, 2008 15th IEEE International Conference on Image Processing, pp.1264-1267, 2008. ,
DOI : 10.1109/ICIP.2008.4711992
Eigen-patch: Position-patch based face hallucination using eigen transformation, 2014 IEEE International Conference on Multimedia and Expo (ICME), pp.1-6, 2014. ,
DOI : 10.1109/ICME.2014.6890206
Hallucinating Face in the DCT Domain, IEEE Transactions on Image Processing, vol.20, issue.10, pp.2769-2779, 2011. ,
DOI : 10.1109/TIP.2011.2142001
Face hallucination using OLPP and Kernel Ridge Regression, 2008 15th IEEE International Conference on Image Processing, pp.353-356, 2008. ,
DOI : 10.1109/ICIP.2008.4711764
Position-based face hallucination method, IEEE Int. Conf. on Multimedia and Expo, pp.290-293, 2009. ,
Position-Patch Based Face Hallucination Using Convex Optimization, IEEE Signal Processing Letters, vol.18, issue.6, pp.367-370, 2011. ,
DOI : 10.1109/LSP.2011.2140370
Positionpatch based face hallucination via locality-constrained representation, IEEE Int. Conf. on Multimedia and Expo, pp.212-217, 2012. ,
Face Hallucination via Similarity Constraints, IEEE Signal Processing Letters, vol.20, issue.1, pp.19-22, 2013. ,
DOI : 10.1109/LSP.2012.2227113
Face Super-Resolution via Multilayer Locality-Constrained Iterative Neighbor Embedding and Intermediate Dictionary Learning, IEEE Transactions on Image Processing, vol.23, issue.10, pp.4220-4231, 2014. ,
DOI : 10.1109/TIP.2014.2347201
A Comprehensive Survey to Face Hallucination, International Journal of Computer Vision, vol.40, issue.11, pp.9-30, 2014. ,
DOI : 10.1007/s11263-013-0645-9
Super-Resolution Reconstruction of Compressed Video Using Transform-Domain Statistics, IEEE Transactions on Image Processing, vol.13, issue.1, pp.33-43, 2004. ,
DOI : 10.1109/TIP.2003.819221
High-resolution images from low-resolution compressed video, IEEE Signal Processing Magazine, vol.20, issue.3, pp.37-48, 2003. ,
DOI : 10.1109/MSP.2003.1203208
Postprocessing of low bitrate block dct coded images based on a fields of experts prior, IEEE Trans. on Image Processing, vol.16, issue.11, pp.2743-2751, 2007. ,
Compression Artifact Reduction by Overlapped-Block Transform Coefficient Estimation With Block Similarity, IEEE Transactions on Image Processing, vol.22, issue.12, pp.4613-4626, 2013. ,
DOI : 10.1109/TIP.2013.2274386
Image deblocking using group-based sparse representation and quantization constraint prior, 2015 IEEE International Conference on Image Processing (ICIP), pp.306-310, 2015. ,
DOI : 10.1109/ICIP.2015.7350809
Postprocessing of JPEG-2000 images to remove compression artifacts, IEEE Signal Processing Letters, vol.10, issue.10, pp.296-299, 2003. ,
DOI : 10.1109/LSP.2003.817179
Locality preserving constraints for super-resolution with neighbor embedding, IEEE Int. Conf. on Image Processing, pp.1189-1192, 2009. ,
The FERET database and evaluation procedure for face-recognition algorithms, Image and Vision Computing, vol.16, issue.5, pp.295-306, 1998. ,
DOI : 10.1016/S0262-8856(97)00070-X
Multi-PIE, Image and Vision Computing, vol.28, issue.5, pp.807-813, 2010. ,
DOI : 10.1016/j.imavis.2009.08.002
Overview of the Face Recognition Grand Challenge, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), pp.947-954, 2005. ,
DOI : 10.1109/CVPR.2005.268
Nist special database 32 multiple encounter dataset ii (meda-ii), Tech. Rep., National Institute of Standards and Technology, 2011. ,
Face Description with Local Binary Patterns: Application to Face Recognition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.28, issue.12, pp.2037-2041, 2006. ,
DOI : 10.1109/TPAMI.2006.244
