Simulation of near-field plasmonic interactions with a local approximation order discontinuous Galerkin time-domain method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Photonics and Nanostructures - Fundamentals and Applications Année : 2016
During the last ten years, the discontinuous Galerkin time-domain (DGTD) method has progressively emerged as a viable alternative to well established finite-difference time-domain (FDTD) and finite-element time-domain (FETD) methods for the numerical simulation of electromagnetic wave propagation problems in the time-domain. The method is now actively studied for various application contexts including those requiring to model light/matter interactions on the nanoscale. In this paper we further demonstrate the capabilities of the method for the simulation of near-field plasmonic interactions by considering more particularly the possibility of combining the use of a locally refined conforming tetrahedral mesh with a local adaptation of the approximation order.
Simulation of near-field plasmonic interactions with a local approximation order discontinuous Galerkin time-domain method.pdf (8.74 Mo) Télécharger le fichier
hal-01389163 , version 1 (28-10-2016)
Jonathan Viquerat, Stéphane Lanteri. Simulation of near-field plasmonic interactions with a local approximation order discontinuous Galerkin time-domain method. Photonics and Nanostructures - Fundamentals and Applications, 2016, 18, pp.43 - 58. ⟨10.1016/j.photonics.2015.12.004⟩. ⟨hal-01389163⟩
331 Consultations
68 Téléchargements
