Miguel León González, and Mário Mollo Neto How Information Systems Assist the Management of the Supply Chain in an Emerging Country Like, p.132 ,
Marins, and Oduvaldo Vendrametto Managing Requirements: For an Integrated Approach from System Engineering to Project Management, p.142 ,
Philippe Esteban, and Rui Xue Supporting Make or Buy Decision for Reconfigurable Manufacturing System, Multi-site Context 150 Youssef Benama, Thècle Alix, and Nicolas Perry Using Unitary Traceability for an Optimal Product Recall . . . . . . . . . . . . . 159 ,
167 Susanne Altendorfer-Kaiser Current Skills Gap in Manufacturing: Towards a New Skills Framework for Factories of the Future, p.175 ,
201 Sara Mahdikhah, Mourad Messaadia, James Xiaoyu Gao Global Value Chains in Shipbuilding: Governance and knowledge, p.209 ,
Towards a Spatiotemporal Ontology-Based on Mereotopological Theory in Assembly-Oriented Design, p.225 ,
Linking Risk Management and Lesson Learnt System for Bidding Process, p.233 ,
Pavol Molnar, and Frantisek Okruhlica Top-Down Definition of Design Spaces Based on Skeleton Modelling, p.249 ,
Gomes Framework for Information Sharing in a Small-to-Medium Port System Supply Chain, p.257 ,
Iskra Dukovska-Popovska, and Anita Friis Sommer Preliminary Requirements and Architecture Definition for Integration of PLM and Business Intelligence Systems, p.265 ,
Hans-Henrik Hvolby, and Iskra Dukovska-Popovska Requirements Engineering for Cyber-Physical Systems: Challenges in the Context of " Industrie 4, A Wiki Based on Crowdsourcing to Share Information about Innovation Support, p.289 ,
Philippe Pernelle, Lilia Gzara, and Michel Tollenaere General Use of the Routing Concept for Supply Chain Modeling Purposes: The Case of, p.323 ,
Saadi Inspection Interval Estimation: A Fuzzy Logic Based RBI Analysis Approach, 334 R.M. Chandima Ratnayake Knowledge-Based Planning and Scheduling ,
345 Mohamed Sabar Designing Interdisciplinary Scheduling Decision Support Systems in Small-Sized SME Environments: The i-DESME Framework, p.355 ,
Cegarra Optimum Arrangement of Taxi Drivers' Working Hours, p.363 ,
Ditlev Brunø Planning Nervousness in Product Segmentation: Empirical Analysis of Decision Parameters, 411 Nicolai Praestholm, Ann-Louise Andersen, Kjeld Nielsen, and Thomas Ditlev Brunø Quantifying the Bullwhip Effect of Multi-echelon System with Stochastic Dependent Lead Time, p.419 ,
Zbigniew Michna, and Izabela Ewa Nielsen Warehouse Capacities in the Pharmaceutical Industry ? Plan or ,
Sporadic " and Systematic Preventive Maintenance Policy for Leased Equipment under Various Operating Conditions, p.451 ,
Lemoine Optimal Storage Assignment for an Automated Warehouse System with Mixed Loading, p.475 ,
Routing Management in Physical Internet Crossdocking Hubs: Study of Grouping Strategies for Truck Loading, p.483 ,
Waefler Industrial Implementation of Models for Joint Production and Maintenance Planning, p.499 ,
Fumagalli Exploring the Integration of Maintenance with Production Management in SMEs, p.507 ,
Making in Dynamically Changing Engineering Construction Projects 515 Hajnalka Vaagen and Bjørnar Aas Analysis of Factors for Implementing TPM: A Study in Welded Tube Manufacturers, ., vol.523, p.531 ,
Choice Knapsack Model for Resource Allocation in a Construction Equipment Manufacturer Setting Using an Evolutionary Algorithm, p.539 ,
Yazg? Tütüncü The Influence of Human Factors on Access and Scheduling of Primary Care Services, p.547 ,
Martina Berglund, and Kezia Scales Table of Contents ? Part I XXI Applicability of Planning and Control in a, Port Environment, p.555 ,
Hans-Henrik Hvolby, and Iskra Dukovska-Popovska A Knowledge-Based Decision-Making Framework for the Design of Manufacturing Networks for Custom-Made Products ,
