KNEWS: Using Logical and Lexical Semantics to Extract Knowledge from Natural Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present KNEWS, a pipeline of NLP tools that accepts natural language text as input and outputs knowledge in a machine-readable format. The tool outputs frame-based knowledge as RDF triples or XML, including the word-level alignment with the surface form, as well as first-order logical formulae. KNEWS is freely available for download. Moreover, thanks to its versatility, KNEWS has already been employed for a number of different applications for information extraction and automatic reasoning.
demo3-NLP.pdf (157.49 Ko) Télécharger le fichier
hal-01389390 , version 1 (28-10-2016)
  • HAL Id : hal-01389390 , version 1
Valerio Basile, Elena Cabrio, Claudia Schon. KNEWS: Using Logical and Lexical Semantics to Extract Knowledge from Natural Language. Proceedings of the European Conference on Artificial Intelligence (ECAI) 2016 conference, Aug 2016, The Hague, Netherlands. ⟨hal-01389390⟩
390 Consultations
322 Téléchargements
