New interface
Conference papers
Fast Computation of the $N$th Term of an Algebraic Series over a Finite Prime Field
Abstract : We address the question of computing one selected term of an algebraic power series. In characteristic zero, the best algorithm currently known for computing the~$N$th coefficient of an algebraic series uses differential equations and has arithmetic complexity quasi-linear in~$\sqrt{N}$. We show that over a prime field of positive characteristic~$p$, the complexity can be lowered to~$O(\log N)$. The mathematical basis for this dramatic improvement is a classical theorem stating that a formal power series with coefficients in a finite field is algebraic if and only if the sequence of its coefficients can be generated by an automaton. We revisit and enhance two constructive proofs of this result for finite prime fields. The first proof uses Mahler equations, whose sizes appear to be prohibitively large. The second proof relies on diagonals of rational functions; we turn it into an efficient algorithm, of complexity linear in~$\log N$ and quasi-linear in~$p$.
Complete list of metadata
https://hal.inria.fr/hal-01389421
Contributor : Philippe Dumas Connect in order to contact the contributor
Submitted on : Friday, October 28, 2016 - 1:55:40 PM
Last modification on : Friday, August 5, 2022 - 9:26:01 AM
Links full text
Identifiers
Citation
Alin Bostan, Gilles Christol, Philippe Dumas. Fast Computation of the $N$th Term of an Algebraic Series over a Finite Prime Field. ISSAC '16, Jul 2016, Waterloo, Ontario, Canada. ⟨10.1145/2930889.2930904⟩. ⟨hal-01389421⟩
Share
Metrics
Record views
377
