New interface
Journal articles
Seeing it all: Convolutional network layers map the function of the human visual system
Abstract : Convolutional networks used for computer vision represent candidate models for the computations performed in mammalian visual systems. We use them as a detailed model of human brain activity during the viewing of natural images by constructing predictive models based on their different layers and BOLD fMRI activations. Analyzing the predictive performance across layers yields characteristic fingerprints for each visual brain region: early visual areas are better described by lower level convolutional net layers and later visual areas by higher level net layers, exhibiting a progression across ventral and dorsal streams. Our predictive model generalizes beyond brain responses to natural images. We illustrate this on two experiments, namely retinotopy and face-place oppositions, by synthesizing brain activity and performing classical brain mapping upon it. The synthesis recovers the activations observed in the corresponding fMRI studies, showing that this deep encoding model captures representations of brain function that are universal across experimental paradigms.
Complete list of metadata
Cited literature [50 references]  Display  Hide  Download
https://hal.inria.fr/hal-01389809
Contributor : Michael Eickenberg Connect in order to contact the contributor
Submitted on : Saturday, October 29, 2016 - 5:22:39 PM
Last modification on : Friday, July 8, 2022 - 10:07:09 AM
File
neuroimage.pdf
Identifiers
Citation
Michael Eickenberg, Alexandre Gramfort, Gaël Varoquaux, Bertrand Thirion. Seeing it all: Convolutional network layers map the function of the human visual system. NeuroImage, 2016, ⟨10.1016/j.neuroimage.2016.10.001⟩. ⟨hal-01389809⟩
Share
Metrics
Record views
1025
Files downloads
7191
