Stability of a Delay System Coupled to a Delay Differential-Difference System Describing the Coexistence of Ordinary and Mutated Hematopoietic Stem Cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— A mathematical model that represents the coexistence of normal and leukemic populations of cells is introduced and analyzed. It is a nonlinear time-delay system characterizing the dynamics of ordinary stem cells, coupled to a delay differential-difference system governing the dynamics of mutated cells. An important feature of this model is that it may explain the invasion of the bone marrow by unhealthy cells that are characterized by fast self-renewing dynamics. A Lyapunov-like technique is developed to investigate the stability properties of a steady state where the population of healthy cells will survive. Exponential stability of solutions is established, estimate on their decay rate is given and an open subset of the basin of attraction of the studied equilibrium is provided.
Automatique
cdc2016walid.pdf (872.37 Ko) Télécharger le fichier
hal-01389870 , version 1 (30-10-2016)
hal-01389870 , version 2 (09-01-2017)
hal-01389870 , version 3 (08-02-2017)
  • HAL Id : hal-01389870 , version 1
Walid Djema, Frédéric Mazenc, Catherine Bonnet, Jean Clairambault, P Hirsch, et al.. Stability of a Delay System Coupled to a Delay Differential-Difference System Describing the Coexistence of Ordinary and Mutated Hematopoietic Stem Cells. Conference on Decision and Control , Dec 2016, Las Vegas, United States. ⟨hal-01389870v1⟩
497 Consultations
448 Téléchargements
