Residual-based a posteriori estimators for the potential formulations of electrostatic and time-harmonic eddy current problems with voltage or current excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Engineering Année : 2016
In this paper, we present some residual-based a posteriori estimators for the potential formulations of electrostatic and time-harmonic eddy current problems with voltage or current excitation. The reliability of the proposed estimators is proved and some numerical experiments are carried out to illustrate the theoretical analysis.
CCNT.pdf (756.88 Ko) Télécharger le fichier
hal-01390241 , version 1 (01-11-2016)
Chao Chen, Emmanuel Creusé, Serge Nicaise, Zuqi Tang. Residual-based a posteriori estimators for the potential formulations of electrostatic and time-harmonic eddy current problems with voltage or current excitation. International Journal for Numerical Methods in Engineering, 2016, 107 (5), pp.377-394 ⟨10.1002/nme.5168⟩. ⟨hal-01390241⟩
171 Consultations
163 Téléchargements
