Conference papers
A Cross-Conformal Predictor for Multi-label Classification
Abstract : Unlike the typical classification setting where each instance is associated with a single class, in multi-label learning each instance is associated with multiple classes simultaneously. Therefore the learning task in this setting is to predict the subset of classes to which each instance belongs. This work examines the application of a recently developed framework called Conformal Prediction (CP) to the multi-label learning setting. CP complements the predictions of machine learning algorithms with reliable measures of confidence. As a result the proposed approach instead of just predicting the most likely subset of classes for a new unseen instance, also indicates the likelihood of each predicted subset being correct. This additional information is especially valuable in the multi-label setting where the overall uncertainty is extremely high.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01391051
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, November 2, 2016 - 5:17:54 PM
Last modification on : Thursday, March 5, 2020 - 5:41:12 PM
Long-term archiving on: : Friday, February 3, 2017 - 3:51:19 PM
File
978-3-662-44722-2_26_Chapter.p...
Identifiers
Citation
Harris Papadopoulos. A Cross-Conformal Predictor for Multi-label Classification. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.241-250, ⟨10.1007/978-3-662-44722-2_26⟩. ⟨hal-01391051⟩
Share
Metrics
Record views
109
Files downloads
122
