Automatically Detected Feature Positions for LBP Based Face Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ladislav Lenc
  • Fonction : Auteur
  • PersonId : 992453
Pavel Král
  • Fonction : Auteur
  • PersonId : 835421
This paper presents a novel approach for automatic face recognition based on the Local Binary Patterns (LBP). One drawback of the current LBP based methods is that the feature positions are fixed and thus do not reflect the properties of the particular images. We propose to solve this issue by a method that automatically detects feature positions in the image. These key-points are determined using the Gabor wavelet transform and k-means clustering algorithm. The proposed method is evaluated on two corpora: AT&T Database of Faces and our Czech News Agency (ČTK) dataset containing uncontrolled face images. The recognition rate on the first dataset is 99.5% which represents 2.5% improvement compared to the original LBP method. The best recognition rate obtained on the ČTK corpus is 59.1% whereas the original LBP method reaches only 38.1%.
978-3-662-44654-6_24_Chapter.pdf (181.19 Ko) Télécharger le fichier
hal-01391321 , version 1 (03-11-2016)
Paternité
Ladislav Lenc, Pavel Král. Automatically Detected Feature Positions for LBP Based Face Recognition. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.246-255, ⟨10.1007/978-3-662-44654-6_24⟩. ⟨hal-01391321⟩
76 Consultations
159 Téléchargements
