Solar Radiation Time-Series Prediction Based on Empirical Mode Decomposition and Artificial Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ioannis Andreadis
  • Fonction : Auteur
  • PersonId : 992492
Nikolaos Georgoulas
  • Fonction : Auteur
  • PersonId : 992493
Michalis Zervakis
  • Fonction : Auteur
  • PersonId : 992494
Nikolaos Nikolaidis
  • Fonction : Auteur
  • PersonId : 992495
This paper presents a new model for daily solar radiation prediction. In order to capture the hidden knowledge of existing data, a time-frequency analysis on past measurements of the solar energy density is carried out. The Hilbert-Huang transform (HHT) is employed for the representation of the daily solar irradiance time series. A set of physical measurements and simulated signals are selected for the time series analysis. The empirical mode decomposition is applied and the adaptive basis of each raw signal is extracted. The decomposed narrow-band amplitude and frequency modulated signals are modelled by using dynamic artificial neural networks (ANNs). Nonlinear autoregressive networks are trained with the average daily solar irradiance as exogenous (independent) input. The instantaneous value of solar radiation density is estimated based on previous values of the time series and previous values of the independent input. The results are promising and they reveal that the proposed system can be incorporated in intelligent systems for better load management in photovoltaic systems.
978-3-662-44654-6_44_Chapter.pdf (977.55 Ko) Télécharger le fichier
hal-01391346 , version 1 (03-11-2016)
Paternité
Petros-Fotios Alvanitopoulos, Ioannis Andreadis, Nikolaos Georgoulas, Michalis Zervakis, Nikolaos Nikolaidis. Solar Radiation Time-Series Prediction Based on Empirical Mode Decomposition and Artificial Neural Networks. 10th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2014, Rhodes, Greece. pp.447-455, ⟨10.1007/978-3-662-44654-6_44⟩. ⟨hal-01391346⟩
109 Consultations
193 Téléchargements
