B. M. Al-hadithi, A. Jiménez, and F. Matía, New Methods for the Estimation of T-S Model Based Extended Kalman Filter and its Applications to Optimal Control for Nonlinear Systems, Optimal Control, Applications and Methods, issue.5, pp.552-575, 2012.
B. M. Al-hadithi, A. Jiménez, and F. Matía, Variable Structure Control with Chattering Reduction of a Generalized T-S Model, Asian Journal of Control, vol.8, issue.6, pp.1-14, 2013.
DOI : 10.1002/asjc.518
B. M. Al-hadithi, A. J. Barragán, J. M. Andújar, and A. Jiménez, Variable Structure Control with chattering elimination and guaranteed stability for a generalized T-S model, Applied Soft Computing, vol.13, issue.12, p.48024812, 2013.
DOI : 10.1016/j.asoc.2013.07.026
B. M. Al-hadithi, A. Jiménez, and F. Matía, A new approach to fuzzy estimation of Takagi???Sugeno model and its applications to optimal control for nonlinear systems, Applied Soft Computing, vol.12, issue.1, pp.280-290, 2012.
DOI : 10.1016/j.asoc.2011.08.044
F. Gang, A survey on analysis and design of model-based fuzzy control systems, IEEE Trans. Fuzzy Syst, vol.14, issue.5, pp.676-697, 2006.
T. Hseng, S. Li, S. , and T. , Fuzzy Bilinear Model and Fuzzy Controller Design for a Class of Nonlinear Systems, IEEE Trans. Fuzzy Syst, vol.15, issue.3, pp.494-506, 2007.
A. Jiménez, B. M. Hadithi, and F. Matía, Improvement of Takagi-Sugeno fuzzy model for the estimation of nonlinear functions, Asian Journal of Control, vol.3, issue.10, pp.14-320, 2012.
DOI : 10.1002/asjc.310
J. E. Slotine and W. Li, Applied nonlinear control, 1991.
T. Takagi and M. Sugeno, Fuzzy identification of systems and its applications to modeling and control, IEEE Transactions on Systems, Man, and Cybernetics, vol.15, issue.1, pp.116-132, 1985.
DOI : 10.1109/TSMC.1985.6313399
D. Tikk, P. Baranyi, and R. J. Patton, Polytopic and TS Models are Nowere Dense in the Approximation Model Space, Proc. IEEE Int. Conf. Syst. Man Cybern. methodology
K. Zeng, N. Y. Zhang, and W. L. Xu, A comparative study on sufficient conditions for Takagi-Sugeno fuzzy systems as universal approximators, IEEE Trans. Fuzzy Syst, vol.8, issue.6, pp.773-780, 2000.
A. J. Barragán, B. M. Al-hadithi, and A. , Jiménez José Manuel Andújar, A general methodology for online TS fuzzy modeling by the extended Kalman filter, Applied soft computing, vol.18, p.277289, 2014.
