Geophysical flows under location uncertainty, Part II Quasi-geostrophy and efficient ensemble spreading
Valentin Resseguier 1, 2, * Etienne Mémin 1 Bertrand Chapron 2
* Corresponding author
1 FLUMINANCE - Fluid Flow Analysis, Description and Control from Image Sequences
IRMAR - Institut de Recherche Mathématique de Rennes, IRSTEA - Institut national de recherche en sciences et technologies pour l'environnement et l'agriculture, Inria Rennes – Bretagne Atlantique
Abstract : Models under location uncertainty are derived assuming that a component of the velocity is uncorrelated in time. The material derivative is accordingly modified to include an advection correction, inhomogeneous and anisotropic diffusion terms and a multiplicative noise contribution. In this paper, simplified geophysical dynamics are derived from a Boussinesq model under location uncertainty. Invoking usual scaling approximations and a moderate influence of the subgrid terms, stochastic formulations are obtained for the stratified Quasi-Geostrophy (QG) and the Surface Quasi-Geostrophy (SQG) models. Based on numerical simulations, benefits of the proposed stochastic formalism are demonstrated. A single realization of models under location uncertainty can restore small-scale structures. An ensemble of realizations further helps to assess model error prediction and outperforms perturbed deterministic models by one order of magnitude. Such a high uncertainty quantification skill is of primary interests for assimilation ensemble methods. MATLAB R code examples are available online.
Complete list of metadatas
https://hal.inria.fr/hal-01391476
Contributor : Valentin Resseguier <>
Submitted on : Friday, March 10, 2017 - 6:47:01 AM
Last modification on : Tuesday, October 1, 2019 - 3:18:14 PM
Long-term archiving on : Sunday, June 11, 2017 - 12:33:36 PM
Geophysical_flows_under_locati...
Identifiers
Citation
Valentin Resseguier, Etienne Mémin, Bertrand Chapron. Geophysical flows under location uncertainty, Part II Quasi-geostrophy and efficient ensemble spreading. Geophysical and Astrophysical Fluid Dynamics, Taylor & Francis, 2017, 111 (3), pp.177-208. ⟨10.1080/03091929.2017.1312101⟩. ⟨hal-01391476v3⟩
Share
Metrics
Record views
1150
Files downloads
414
