Numerical modeling of electron beam interactions with metallic nanostructures using high order time domain solvers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent advances in fabrication technologies of metallic nanostructures have opened a new branch of nanophotonics. Those structures show significantly different behaviour compared to the mi- crowave regime due to the negative refraction index of noble metals at optical frequencies. Popular applications are for example light harvesting, cancer therapy, molecule sensoring, light guid- ing, higher harmonic generation, and enhanced spontaneous emission. However, since many effects take place in the evanescent near field, special measurement techniques are required in order to investigate those structures. This work is dedicated to the numerical modeling of electron beam based microscopy techniques like Electron Energy Loss Spectroscopy (EELS) and Cathodoluminescence (CL).
Fichier non déposé
hal-01391575 , version 1 (03-11-2016)
  • HAL Id : hal-01391575 , version 1
Nikolai Schmitt, Claire Scheid, Stephane Lanteri. Numerical modeling of electron beam interactions with metallic nanostructures using high order time domain solvers. School of Plasmonics 2016, Jul 2016, Cortona, Italy. ⟨hal-01391575⟩
110 Consultations
0 Téléchargements
