Surface heat-flux fluctuations in a turbulent channel flow up to Re??=1020 with Pr=0.025 and 0.71, International Journal of Heat and Fluid Flow, vol.25, issue.3, pp.404-419, 2004. ,
DOI : 10.1016/j.ijheatfluidflow.2004.02.010
Code Saturne: A Finite Volume Code for the Computation of Turbulent Incompressible flows -Industrial Applications, Int. J. on Finite, issue.0655, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01115371
Application of Advanced Reynolds Stress Transport Models to Highly Separated Flows, Proc. 7th Int. Symp. Turb. Shear Flow Phenomena, 2011. ,
A robust k????????/k elliptic blending turbulence model applied to near-wall, separated and buoyant flows, International Journal of Heat and Fluid Flow, vol.33, issue.1, pp.45-58, 2012. ,
DOI : 10.1016/j.ijheatfluidflow.2011.11.003
Prediction of Cascade Flows With Innovative Second-Moment Closures, Journal of Fluids Engineering, vol.127, issue.6, pp.1059-1070, 2005. ,
DOI : 10.1115/1.2073267
Treatment of turbulent heat fluxes with the elliptic-blending second-moment closure for turbulent natural convection flows, International Journal of Heat and Mass Transfer, vol.51, issue.9-10, pp.9-10, 2008. ,
DOI : 10.1016/j.ijheatmasstransfer.2007.08.012
Transport Equations in Turbulence, Physics of Fluids, vol.13, issue.11, pp.2634-2649, 1970. ,
DOI : 10.1063/1.1692845
Modélisation statistique desécoulementsdesécoulements turbulents en convection forcée, mixte et naturelle, 2012. ,
Algebraic Modeling of the Turbulent Heat Fluxes Using the Elliptic Blending Approach???Application to Forced and Mixed Convection Regimes, Flow, Turbulence and Combustion, vol.36, issue.8, pp.77-100, 2012. ,
DOI : 10.1007/s10494-011-9366-8
A comparative assessment of the second-moment differential and algebraic models in turbulent natural convection, International Journal of Heat and Fluid Flow, vol.18, issue.1, pp.4-14, 1997. ,
DOI : 10.1016/S0142-727X(96)00149-X
Near-Wall Turbulence Closure Modeling Without " Damping Functions, Theor. Comput. Fluid Dyn, vol.3, pp.1-13, 1991. ,
DNS of turbulent channel flow with conjugate heat transfer: Effect of thermal boundary conditions on the second moments and budgets, International Journal of Heat and Fluid Flow, vol.55, pp.34-44, 2015. ,
DOI : 10.1016/j.ijheatfluidflow.2015.07.009
URL : https://hal.archives-ouvertes.fr/hal-01321586
Modelling Turbulence in Engineering and the Environment. Second-Moment Routes to Closure, 2011. ,
A robust near-wall elliptic relaxation eddy-viscosity turbulence model for CFD, 2004. ,
Large eddy simulation in Code Saturne of thermal mixing in a T junction with brass wall, Proc. 8th Int. Symp. Turbulence, Heat and Mass Transfer, 2015. ,
Direct numerical simulation of combined forced and natural turbulent convection in a vertical plane channel, International Journal of Heat and Fluid Flow, vol.18, issue.1, pp.88-99, 1997. ,
DOI : 10.1016/S0142-727X(96)00148-8
Contribution to elliptic relaxation modelling of turbulent natural and mixed convection, International Journal of Heat and Fluid Flow, vol.26, issue.4, pp.569-586, 2005. ,
DOI : 10.1016/j.ijheatfluidflow.2005.03.007
On the Computation of Convective Heat Transfer in Complex Turbulent Flows, Journal of Heat Transfer, vol.110, issue.4b, pp.1112-1128, 1988. ,
DOI : 10.1115/1.3250614
A robust formulation of the v2?f model. Flow Turbul, Combust, vol.73, pp.3-4, 2005. ,
Recent progress in the development of the Elliptic Blending Reynolds-stress model, International Journal of Heat and Fluid Flow, vol.51, pp.195-220, 2015. ,
DOI : 10.1016/j.ijheatfluidflow.2014.09.002
URL : https://hal.archives-ouvertes.fr/hal-01092931
Elliptic blending model: A new near-wall Reynolds-stress turbulence closure, Physics of Fluids, vol.14, issue.2, pp.744-754, 2002. ,
DOI : 10.1063/1.1432693
Turbulent heat transfer predictions using the ???f model on unstructured meshes, International Journal of Heat and Fluid Flow, vol.21, issue.3, pp.320-328, 2000. ,
DOI : 10.1016/S0142-727X(00)00016-3
Inhomogeneity and anisotropy effects on the redistribution term in Reynolds-averaged Navier???Stokes modelling, Journal of Fluid Mechanics, vol.438, pp.307-338, 2001. ,
DOI : 10.1017/S0022112001004451
Reynolds-stress and dissipation-rate budgets in a turbulent channel flow, Journal of Fluid Mechanics, vol.129, issue.-1, pp.15-44, 1988. ,
DOI : 10.1007/BF01329645
Two-equation eddy-viscosity turbulence models for engineering applications, AIAA Journal, vol.32, issue.8, pp.1598-1605, 1994. ,
DOI : 10.2514/3.12149
Predictions of Turbulent Heat Transfer in an Axisymmetric Jet Impinging on a Heated Pedestal, Journal of Heat Transfer, vol.121, issue.1, pp.1-7, 1998. ,
DOI : 10.1115/1.2825964
The Reynolds-stress model of turbulence applied to the natural-convection boundary layer along a heated vertical plate, International Journal of Heat and Mass Transfer, vol.35, issue.2, pp.403-420, 1992. ,
DOI : 10.1016/0017-9310(92)90278-Z
Turbulent Flows, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00338511
Second-moment closure for turbulent scalar transport at various Prandtl numbers, International Journal of Heat and Mass Transfer, vol.39, issue.14, pp.2977-2987, 1996. ,
DOI : 10.1016/0017-9310(95)00339-8
Elliptic relaxation second moment closure for the turbulent heat fluxes, J. Turbul, vol.9, issue.3, pp.1-29, 2008. ,
Modelling the pressure???strain correlation of turbulence: an invariant dynamical systems approach, Journal of Fluid Mechanics, vol.45, issue.-1, pp.245-272, 1991. ,
DOI : 10.1063/1.857575
Computations of Flow Field and Heat Transfer in a Stator Vane Passage Using the v[sup 2]?????f Turbulence Model, Journal of Turbomachinery, vol.127, issue.3, pp.627-634, 2005. ,
DOI : 10.1115/1.1929820
Predictions of flow and heat transfer in multiple impinging jets with an ellipticblending second-moment closure, Int. J. Heat Mass Tran, issue.8, pp.48-1583, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00147794
DNS of Turbulent Heat Transfer in Channel Flow With Heat Conduction in the Solid Wall, Journal of Heat Transfer, vol.123, issue.5, pp.849-857, 2001. ,
DOI : 10.1115/1.1389060
Direct numerical simulations of two-and three-dimensional turbulent natural convection flows in a differentially, 2007. ,
Development of an explicit algebraic turbulence model for buoyant flows ??? Part 2: Model development and validation, International Journal of Heat and Fluid Flow, vol.53, 2014. ,
DOI : 10.1016/j.ijheatfluidflow.2014.07.006
Turbulent budgets of natural convection in an infinite, differentially heated, vertical channel, International Journal of Heat and Fluid Flow, vol.19, issue.2, pp.135-149, 1998. ,
DOI : 10.1016/S0142-727X(97)10018-2
Numerical study of stress-transport turbulence models: Implementation and validation issues, Computers & Fluids, vol.36, issue.8, pp.1373-1383, 2007. ,
DOI : 10.1016/j.compfluid.2006.11.006
