Sharing through Collaborative Spaces: Enhancing Collaborative Networks Interoperability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Within collaborative networks, information sharing and knowledge creation are the main drives for value creation, wherever collaborative spaces (CS) has been used as the means to enable collaboration among the different social actors involved. Despite of technological availability, CS still a challenge in practice, mainly due to the lack of methods to support its development and to its tight coupling with the collaboration model adopted by the network. Thus, the main focus of this paper in on enhancing information sharing through the design of what we call agnostic collaborative spaces (ACS), supported by linked data approaches. Beyond this new perspective over CS, it is discussed a technological solution through which ACS are implemented.
978-3-662-44745-1_48_Chapter.pdf (499.14 Ko) Télécharger le fichier
hal-01392154 , version 1 (04-11-2016)
Paternité
Cristóvão Sousa, Carla Pereira. Sharing through Collaborative Spaces: Enhancing Collaborative Networks Interoperability. 15th Working Conference on Virtual Enterprises (PROVE), Oct 2014, Amsterdam, Netherlands. pp.481-488, ⟨10.1007/978-3-662-44745-1_48⟩. ⟨hal-01392154⟩
61 Consultations
63 Téléchargements
