A robust and stable numerical scheme for a depth-averaged Euler system -https, 2015. ,
A multilayer Saint-Venant model : Derivation and numerical validation, Discrete Contin, Dyn. Syst. Ser. B, vol.5, issue.2, pp.189-214, 2005. ,
DOI : 10.3934/dcdsb.2005.5.189
URL : http://www.aimsciences.org/journals/doIpChk.jsp?paperID=928&mode=full
Kinetic entropy inequality and hydrostatic reconstruction scheme for the Saint-Venant system, Mathematics of Computation, vol.85, issue.302, pp.2815-2837, 2016. ,
DOI : 10.1090/mcom/3099
URL : https://hal.archives-ouvertes.fr/hal-01063577
A well-balanced positivity preserving ???second-order??? scheme for shallow water flows on unstructured meshes, Journal of Computational Physics, vol.206, issue.1, pp.311-333, 2005. ,
DOI : 10.1016/j.jcp.2004.12.016
URL : https://hal.archives-ouvertes.fr/inria-00070738
Numerical simulations of 3D free surface flows by a multilayer Saint-Venant model, International Journal for Numerical Methods in Fluids, vol.12, issue.3, pp.331-350, 2008. ,
DOI : 10.1002/fld.1534
Approximation of the hydrostatic Navier-Stokes system for density stratified flows by a multilayer model. Kinetic interpretation and numerical validation, J. Comp. Phys, pp.230-3453, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00654642
A multilayer Saint-Venant system with mass exchanges for shallow water flows. Derivation and numerical validation, ESAIM: Mathematical Modelling and Numerical Analysis, vol.45, issue.1, pp.2-45, 2011. ,
DOI : 10.1051/m2an/2010036
URL : https://hal.archives-ouvertes.fr/inria-00551428
Kinetic entropy for layer-averaged hydrostatic Navier-Stokes equations, submitted, 2017. ,
Relaxation to isentropic gas dynamics for a BGK system with single kinetic entropy, Methods and Applications of Analysis, vol.9, issue.2, pp.313-327, 2002. ,
DOI : 10.4310/MAA.2002.v9.n2.a7
Construction of BGK models with a family of kinetic entropies for a given system of conservation laws, J. Stat. Phys, pp.95-113, 1999. ,
An entropy satisfying scheme for two-layer shallow water equations with uncoupled treatment, ESAIM: Mathematical Modelling and Numerical Analysis, vol.42, issue.4, pp.683-698, 2008. ,
DOI : 10.1051/m2an:2008019
Gravity driven shallow water models for arbitrary topography, Communications in Mathematical Sciences, vol.2, issue.3, pp.359-389, 2004. ,
DOI : 10.4310/CMS.2004.v2.n3.a2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.138.8596
A robust well-balanced scheme for multi-layer shallow water equations, Discrete Contin, Dyn. Syst. Ser. B, vol.13, pp.739-758, 2010. ,
Analytical solutions for the free surface hydrostatic Euler equations, Communications in Mathematical Sciences, vol.11, issue.4, pp.993-1010, 2013. ,
DOI : 10.4310/CMS.2013.v11.n4.a5
URL : https://hal.archives-ouvertes.fr/hal-00751685
Homogeneous hydrostatic flows with convex velocity profiles, Nonlinearity, vol.12, issue.3, pp.495-512, 1999. ,
DOI : 10.1088/0951-7715/12/3/004
Layer-averaged Euler and Navier???Stokes equations, Layer-averaged Euler and Navier- Stokes equations, pp.1221-1246, 2017. ,
DOI : 10.4310/CMS.2017.v15.n5.a3
URL : https://hal.archives-ouvertes.fr/hal-01202042
An energy-consistent depth-averaged euler system: Derivation and properties, Discrete and Continuous Dynamical Systems -Series, pp.961-988, 2015. ,
DOI : 10.3934/dcdsb.2015.20.961
URL : http://www.aimsciences.org/journals/doIpChk.jsp?paperID=10801&mode=full
Boundary Conditions for the Shallow Water Equations solved by Kinetic Schemes, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072305
-scheme for a class of systems of coupled conservation laws with source term. Application to a two-layer 1-D shallow water system, ESAIM: Mathematical Modelling and Numerical Analysis, vol.35, issue.1, pp.107-127, 2001. ,
DOI : 10.1051/m2an:2001108
URL : https://hal.archives-ouvertes.fr/hal-01478904
Vázquez- Cendón, Numerical simulation of two-layer shallow water flows through channels with irregular geometry, J. Comput. Phys, issue.1, pp.195-202, 2004. ,
A semi-implicit numerical method for the free-surface Navier-Stokes equations, International Journal for Numerical Methods in Fluids, vol.53, issue.8, pp.605-622, 2014. ,
DOI : 10.1017/S0022112081001882
A multilayer shallow model for dry granular flows with the -rheology: application to granular collapse on erodible beds, Journal of Fluid Mechanics, vol.11, 2016. ,
DOI : 10.1016/0021-9991(80)90163-1
A Multilayer Method for the Hydrostatic Navier-Stokes Equations: A Particular Weak Solution, Journal of Scientific Computing, vol.40, issue.2, pp.408-437, 2014. ,
DOI : 10.1137/S0036142901390378
A new two-dimensional Shallow Water model including pressure effects and slow varying bottom topography, ESAIM: Mathematical Modelling and Numerical Analysis, vol.38, issue.2, pp.211-234, 2004. ,
DOI : 10.1051/m2an:2004010
URL : http://www.esaim-m2an.org/articles/m2an/pdf/2004/02/m2an0302.pdf
Derivation of Viscous Saint-Venant System for Laminar Shallow Water; Numerical Validation, Discrete Contin, Dyn. Syst. Ser. B, vol.1, issue.1, pp.89-102, 2001. ,
On the derivation of homogeneous hydrostatic equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.33, issue.5, pp.2-33, 1999. ,
DOI : 10.1051/m2an:1999128
Fault slip distribution of the 2014 Iquique, Chile, earthquake estimated from ocean-wide tsunami waveforms and GPS data, Geophysical Research Letters, vol.41, issue.2B, pp.1053-1060, 2015. ,
DOI : 10.1002/2014GL060274
Hydrodynamics of free surface flows: Modelling with the finite element method, 2007. ,
DOI : 10.1002/9780470319628
A shallow water model with eddy viscosity for basins with varying bottom topography, Nonlinearity, vol.14, issue.6, pp.1493-1515, 2001. ,
DOI : 10.1088/0951-7715/14/6/305
Derivation of a new two-dimensional viscous shallow water model with varying topography, bottom friction and capillary effects, European Journal of Mechanics - B/Fluids, vol.26, issue.1, pp.49-63, 2007. ,
DOI : 10.1016/j.euromechflu.2006.04.007
On the Hs theory of hydrostatic Euler equations, Archive for Rational Mechanics and Analysis, pp.231-271, 2012. ,
Two-layer ?Shallow water? model, Journal of Applied Mechanics and Technical Physics, vol.2, issue.2, pp.3-14, 1979. ,
DOI : 10.1007/BF00910010
Kinetic formulation of conservation laws, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01146188
A kinetic scheme for the Saint-Venant system??with a source term, Calcolo, vol.38, issue.4, pp.201-231, 2001. ,
DOI : 10.1007/s10092-001-8181-3
URL : https://hal.archives-ouvertes.fr/hal-00922664
VERTICALLY AVERAGED MODELS FOR THE FREE SURFACE NON-HYDROSTATIC EULER SYSTEM: DERIVATION AND KINETIC INTERPRETATION, Mathematical Models and Methods in Applied Sciences, vol.49, issue.03, pp.459-490, 2011. ,
Some exact solutions to the nonlinear shallow-water wave equations, Journal of Fluid Mechanics, vol.8, issue.-1, pp.499-508, 1981. ,
DOI : 10.1017/S0022112058000331
Complex rupture of an apparently simple asperity during the, EGU General Assembly Conference Abstracts, pp.2016-8660, 2014. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, With an introduction by Ch. Hirsch, Commemoration of the 30th anniversary {of J. Comput. Phys.}. MR 1486274, pp.227-248, 1997. ,
DOI : 10.1016/0021-9991(79)90145-1
Two-layer shallow-water flow in two dimensions, a numerical study, Journal of Computational Physics, vol.33, issue.2, pp.169-184, 1979. ,
DOI : 10.1016/0021-9991(79)90014-7
Traveltime delay and initial phase reversal of distant tsunamis coupled with the self-gravitating elastic Earth, Journal of Geophysical Research: Solid Earth, vol.39, issue.2, pp.4287-4310, 2014. ,
DOI : 10.1029/2012GL053068
