A two-dimensional method for a family of dispersive shallow water model, 2019. ,
A multilayer Saint-Venant model : Derivation and numerical validation, Discrete Contin. Dyn. Syst. Ser. B, vol.5, issue.2, pp.189-214, 2005. ,
A fast and stable wellbalanced scheme with hydrostatic reconstruction for Shallow Water flows, SIAM J. Sci. Comput, vol.25, issue.6, pp.2050-2065, 2004. ,
Kinetic entropy inequality and hydrostatic reconstruction scheme for the Saint-Venant system, Math. Comp, vol.85, issue.302, pp.2815-2837, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01063577
A well-balanced positivity preserving second-order scheme for Shallow Water flows on unstructured meshes, J. Comput. Phys, vol.206, issue.1, pp.311-333, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00070738
, Finite-volume solvers for a multilayer Saint-Venant system, Int. J. Appl. Math. Comput. Sci, vol.17, issue.3, pp.311-319, 2007.
Numerical simulations of 3d free surface flows by a multilayer Saint-Venant model, Internat. J. Numer. Methods Fluids, vol.56, issue.3, pp.331-350, 2008. ,
Approximation of the hydrostatic Navier-Stokes system for density stratified flows by a multilayer model. Kinetic interpretation and numerical validation, J. Comp. Phys, vol.230, pp.3453-3478, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00654642
A multilayer Saint-Venant system with mass exchanges for Shallow Water flows. Derivation and numerical validation, ESAIM, pp.169-200, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00355730
Kinetic entropy for the layer-averaged hydrostatic Navier-Stokes equations, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01583511
, Théorie du mouvement non permanent des eaux avec applications aux crues des rivières et à l'introduction des marées dans leur lit, C. R. Acad. Sci. Paris, vol.73, pp.147-154, 1871.
, A 2d model for hydrodynamics and biology coupling applied to algae growth simulations, vol.47, pp.1387-1412, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00936859
Relaxation to isentropic gas dynamics for a BGK system with single kinetic entropy, Methods Appl. Anal, vol.9, issue.2, pp.313-327, 2002. ,
Construction of BGK models with a family of kinetic entropies for a given system of conservation laws, J. Stat. Phys, vol.95, pp.113-170, 1999. ,
, Entropy satisfying flux vector splittings and kinetic BGK models, Numer. Math, vol.94, pp.623-672, 2003.
, An introduction to finite volume methods for hyperbolic conservation laws, ESAIM Proc, vol.15, pp.107-127, 2004.
, Nonlinear stability of finite volume methods for hyperbolic conservation laws and wellbalanced schemes for sources, 2004.
An entropy satisfying scheme for two-layer shallow water equations with uncoupled treatment, M2AN Math. Model. Numer. Anal, vol.42, pp.683-698, 2008. ,
Gravity driven shallow water models for arbitrary topography, Comm. in Math. Sci, vol.2, pp.359-389, 2004. ,
A robust well-balanced scheme for multi-layer shallow water equations, Discrete Contin. Dyn. Syst. Ser. B, vol.13, pp.739-758, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00538338
Analytical solutions for the free surface hydrostatic Euler equations, Commun. Math. Sci, vol.11, issue.4, pp.993-1010, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00751685
Homogeneous hydrostatic flows with convex velocity profiles, Nonlinearity, vol.12, issue.3, pp.495-512, 1999. ,
On the two-dimensional hydrostatic Navier-Stokes equations, MR 2111916, vol.36, pp.796-814, 2004. ,
Layer-averaged Euler and Navier-Stokes equations, Commun. Math. Sci, vol.15, issue.5, pp.1221-1246, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01202042
Various analytical solutions for the incompressible Euler and Navier-Stokes systems with free surface, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01831622
An energy-consistent depthaveraged euler system: Derivation and properties, Discrete and Continuous Dynamical Systems -Series B, vol.20, issue.4, pp.961-988, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01011691
Boundary Conditions for the Shallow Water Equations solved by Kinetic Schemes, INRIA, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072305
A Q-scheme for a class of systems of coupled conservation laws with source term, M2AN Math. Model. Numer. Anal, vol.35, issue.1, pp.107-127, 2001. ,
Numerical simulation of two-layer shallow water flows through channels with irregular geometry, J. Comput. Phys, vol.195, issue.1, pp.202-235, 2004. ,
A semi-implicit numerical method for the free-surface Navier-Stokes equations, Internat. J. Numer. Methods Fluids, vol.74, issue.8, pp.605-622, 2014. ,
, Clawpack software, 2019.
How do microalgae perceive light in a high-rate pond? Towards more realistic Lagrangian experiments, Royal Society Open Science, vol.5, issue.5, p.180523, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01830067
A multilayer shallow model for dry granular flows with the µ(I)-rheology: Application to granular collapse on erodible beds, Journal of Fluid Mechanics, vol.798, pp.643-681, 2016. ,
A multilayer method for the hydrostatic Navier-Stokes equations: a particular weak solution, Journal of Scientific Computing, vol.60, issue.2, pp.408-437, 2014. ,
On the derivation of homogeneous hydrostatic equations, ESAIM, issue.5, pp.965-970, 1999. ,
Fault slip distribution of the 2014 iquique, chile, earthquake estimated from ocean-wide tsunami waveforms and gps data, Geophysical Research Letters, vol.42, issue.4, pp.1053-1060, 2015. ,
Hydrodynamics of free surface flows: Modelling with the finite element method, 2007. ,
, Incompressible models, vol.1, 1996.
Advanced numerical models for simulating tsunami waves and runup, vol.10, 2008. ,
Performance benchmarking of tsunami-hysea model for nthmp's inundation mapping activities, Pure and Applied Geophysics, vol.174, issue.8, pp.3147-3183, 2017. ,
On the Hs theory of hydrostatic Euler equations, Archive for Rational Mechanics and, Analysis, vol.204, issue.1, pp.231-271, 2012. ,
, Proceedings and results of the 2011 nthmp model benchmarking workshop, 2012.
Two-layer shallow water models, Prikl. Mekh. Tekh. Fiz, vol.2, pp.3-14, 1979. ,
Kinetic formulation of conservation laws, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01146188
A kinetic scheme for the Saint-Venant system with a source term, Calcolo, vol.38, issue.4, pp.201-231, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00922664
, , 2017.
Vertically averaged models for the free surface Euler system. Derivation and kinetic interpretation, Math. Models Methods Appl. Sci. (M3AS), vol.21, issue.3, pp.459-490, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00551484
, , 2017.
Some exact solutions to the non-linear shallow-water wave equations, J. Fluid Mech, vol.107, pp.499-508, 1981. ,
Complex rupture of an apparently simple asperity during the 2014/04/01 pisagua earthquake (northern chile, mw=8.1), EGU General Assembly Conference Abstracts, vol.18, pp.2016-8660, 2016. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to Godunov's method, J. Comput. Phys.}. MR, vol.135, issue.2, p.1486274, 1997. ,
Two-layer shallow-water flow in two dimensions, a numerical study, J. Comput. Phys, vol.33, pp.169-184, 1979. ,
Traveltime delay and initial phase reversal of distant tsunamis coupled with the self-gravitating elastic earth, Journal of Geophysical Research: Solid Earth, vol.119, issue.5, pp.4287-4310, 2014. ,
