Kernel estimation of extreme regression risk measures
Abstract : The Regression Conditional Tail Moment (RCTM) is the risk measure defined as the moment of order b ≥ 0 of a loss distribution above the upper α-quantile where α ∈ (0, 1) and when a covariate information is available. The purpose of this work is first to establish the asymptotic properties of the RCTM in case of extreme losses, i.e when α → 0 is no longer fixed, under general extreme-value conditions on their distribution tail. In particular, no assumption is made on the sign of the associated extreme-value index. Second, the asymptotic normality of a kernel estimator of the RCTM is established, which allows to derive similar results for estimators of related risk measures such as the Regression Conditional Tail Expectation/Variance/Skewness. When the distribution tail is upper bounded, an application to frontier estimation is also proposed. The results are illustrated both on simulated data and on a real dataset in the field of nuclear reactors reliability.
Type de document :
Pré-publication, Document de travail
2017
Liste complète des métadonnées
https://hal.inria.fr/hal-01393519
Contributeur : Stephane Girard <>
Soumis le : mercredi 15 mars 2017 - 15:13:00
Dernière modification le : jeudi 11 janvier 2018 - 06:22:38
Document(s) archivé(s) le : vendredi 16 juin 2017 - 14:00:17
Fichier
RCTM_allDA7.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01393519, version 2
Citation
Jonathan El Methni, Laurent Gardes, Stephane Girard. Kernel estimation of extreme regression risk measures. 2017. 〈hal-01393519v2〉
Métriques
Consultations de la notice
670
Téléchargements de fichiers
69
