Co-scheduling algorithms for cache-partitioned systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Cache-partitioned architectures allow subsections of the shared last-level cache (LLC) to be exclusively reserved for some applications. This technique dramatically limits interactions between applications that are concurrently executing on a multi-core machine. Consider n applications that execute concurrently, with the objective to minimize the makespan, defined as the maximum completion time of the n applications. Key scheduling questions are: (i) which proportion of cache and (ii) how many processors should be given to each application? Here, we assign rational numbers of processors to each application, since they can be shared across applications through multi-threading. In this paper, we provide answers to (i) and (ii) for perfectly parallel applications. Even though the problem is shown to be NP-complete, we give key elements to determine the subset of applications that should share the LLC (while remaining ones only use their smaller private cache). Building upon these results, we design efficient heuristics for general applications. Extensive simulations demonstrate the usefulness of co-scheduling when our efficient cache partitioning strategies are deployed.
RR-8965.pdf (1.23 Mo) Télécharger le fichier
hal-01393989 , version 1 (08-11-2016)
  • HAL Id : hal-01393989 , version 1
Guillaume Aupy, Anne Benoit, Loïc Pottier, Padma Raghavan, Yves Robert, et al.. Co-scheduling algorithms for cache-partitioned systems. [Research Report] RR-8965, INRIA Grenoble - Rhone-Alpes; ENS de Lyon. 2016, pp.28. ⟨hal-01393989⟩
214 Consultations
162 Téléchargements
