Natural Interpretation of UML/MARTE Diagrams for System Requirements Specification
To verify embedded systems early in the design stages, we need formal ways to requirements specification which can be as close as possible to natural language interpretation, away from the lower ESL/RTL levels. This paper proposes to contribute to the FSL (Formal Specification Level) by specifying natural language requirements graphically in the form of temporal patterns. Standard modeling artifacts like UML and MARTE are used to provide formal semantics of these graphical models allowing to eliminate ambiguity in specifications and automatic design verification at different abstraction levels using these patterns.
Systèmes embarqués
