Implementing HOL in an Higher Order Logic Programming Language
We present a proof-of-concept prototype of a (constructive variant of an) HOL interactive theorem prover written in a Higher Order Logic Programming (HOLP) language, namely an extension of λProlog. The prototype is meant to support the claim, that we reinforce , that HOLP is the class of languages that provides the right abstraction level and programming primitives to obtain concise implementations of theorem provers. We identify and advocate for a programming technique, that we call semi-shallow embedding, while at the same time identifying the reasons why pure λProlog is not sufficient to support that technique, and it needs to be extended.
