Implementing HOL in an Higher Order Logic Programming Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a proof-of-concept prototype of a (constructive variant of an) HOL interactive theorem prover written in a Higher Order Logic Programming (HOLP) language, namely an extension of λProlog. The prototype is meant to support the claim, that we reinforce , that HOLP is the class of languages that provides the right abstraction level and programming primitives to obtain concise implementations of theorem provers. We identify and advocate for a programming technique, that we call semi-shallow embedding, while at the same time identifying the reasons why pure λProlog is not sufficient to support that technique, and it needs to be extended.
holsuperlight.pdf (241.27 Ko) Télécharger le fichier
hal-01394686 , version 1 (09-11-2016)
Cvetan Dunchev, Claudio Sacerdoti Coen, Enrico Tassi. Implementing HOL in an Higher Order Logic Programming Language. Logical Frameworks and Meta Languages: Theory and Practice, Jun 2016, Porto, Portugal. pp.10, ⟨10.1145/2966268.2966272⟩. ⟨hal-01394686⟩
175 Consultations
332 Téléchargements
