An Information theoretical problem in interactive Multi-View Video services
This paper presents a novel information theoretical for Free-Viewpoint Television. In particular, it is stated that Free-Viewpoint Television can be transmitted at the compression rate than traditional predictive video coding such as MPEG-like video coders.
MMTC16_AR_An Information theoretical problem in interactive Multi-View Video services.pdf (319.59 Ko)
Télécharger le fichier
