Numerical Methods for Nonsmooth Dynamical Systems, Lecture Notes in Applied and Computational Mechanics, vol.35, pp.10-1007, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Higher order Moreau???s sweeping process: mathematical formulation and numerical simulation, Mathematical Programming, vol.43, issue.4, pp.133-217, 2008. ,
DOI : 10.1007/BFb0109998
URL : http://www.inrialpes.fr/bipop/publis/AcBrGo2008MATHPROGA.pdf
A qualitative mathematical analysis of a class of linear variational inequalities via semi-complementarity problems: applications in electronics, Mathematical Programming, vol.167, issue.1, pp.31-6710, 2011. ,
DOI : 10.1515/9781400873173
Dynamics of Mechanical Systems with Coulomb Friction, Foundations of Mechanical Engineering, 2003. ,
DOI : 10.1007/978-3-540-36516-7
Augmented lagrangian and mass-orthogonal projection methods for constrained multibody dynamics, Nonlinear Dynamics, vol.14, issue.1-2, pp.113-13010, 1996. ,
DOI : 10.1007/978-3-642-50995-7
Matrix, Mathematics. Theory, Facts, and Formulas with Application to Linear Systems Theory, 2005. ,
Augmented Lagrangian formulation: geometrical interpretation and application to systems with singularities and redundancy, Multibody System Dynamics, vol.8, issue.2, pp.141-159, 2002. ,
DOI : 10.1023/A:1019581227898
Convex Optimization, 2004. ,
Inertial couplings between unilateral and bilateral holonomic constraints in frictionless Lagrangian systems, Multibody System Dynamics, vol.2, issue.6, pp.289-325, 2013. ,
DOI : 10.1007/978-3-642-01100-9
URL : https://hal.archives-ouvertes.fr/hal-00825581
Kinetic quasi-velocities in unilaterally constrained Lagrangian mechanics with impacts and friction, Multibody System Dynamics, vol.8, issue.5, pp.175-216, 2014. ,
DOI : 10.1137/S1064827596297227
URL : https://hal.archives-ouvertes.fr/hal-00762986
Singular mass matrix and redundant constraints in unilaterally constrained Lagrangian and Hamiltonian systems, Multibody System Dynamics, vol.32, issue.2, pp.39-6110, 2015. ,
DOI : 10.1016/S0167-6911(97)00054-6
URL : https://hal.archives-ouvertes.fr/hal-01088286
Existence and uniqueness of solutions for non-autonomous complementarity dynamical systems, J. Convex Anal, vol.17, pp.3-4, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00756226
Convergence of the generalized ? scheme for constrained mechanical systems, Multibody Syst. Dyn, vol.18, issue.2, pp.185-202, 2007. ,
Perturbation Bounds of P-Matrix Linear Complementarity Problems, SIAM Journal on Optimization, vol.18, issue.4, pp.1250-1265, 2007. ,
DOI : 10.1137/060653019
On a Problem in Linear Inequalities, Journal of the London Mathematical Society, vol.1, issue.1, pp.378-384, 1968. ,
DOI : 10.1112/jlms/s1-43.1.378
The Linear Complementarity Problem, Computer Science and Scientific Computing, 1992. ,
The contact problem for linear continuous-time dynamical systems: a geometric approach, IEEE Transactions on Automatic Control, vol.42, issue.4, pp.458-472, 1997. ,
DOI : 10.1109/9.566656
Determination of Holonomic and Nonholonomic Constraint Reactions in an Index-3 Augmented Lagrangian Formulation With Velocity and Acceleration Projections, Journal of Computational and Nonlinear Dynamics, vol.9, issue.4, p.41006, 2014. ,
DOI : 10.1115/1.4027671
Finite-Dimensional Variational Inequalities and Complementarity Problems, Operations Research, vol.1, 2003. ,
On the unique solvability of a direct dynamics problem for mechanisms with redundant constraints and Coulomb friction in joints, Mechanism and Machine Theory, vol.46, issue.3, pp.312-334, 2011. ,
DOI : 10.1016/j.mechmachtheory.2010.11.003
New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, pp.653-67710, 1999. ,
DOI : 10.1016/S0997-7538(99)00144-8
The Principles of d'Alembert, Jourdain, and Gauss in Nonsmooth Dynamics Part I: Scleronomic Multibody Systems, ZAMM, vol.78, issue.1, pp.21-37, 1998. ,
DOI : 10.1002/(SICI)1521-4001(199801)78:1<21::AID-ZAMM21>3.0.CO;2-W
URL : https://hal.archives-ouvertes.fr/hal-01379709
Set-Valued Force Laws: Dynamics of Non-Smooth Systems, 2001. ,
DOI : 10.1007/978-3-540-44479-4
Solving Ordinary Differential Equations II. Stiff and Differential-Algebraic Problems, Series in Computational Mathematics, 1996. ,
DOI : 10.1007/978-3-642-05221-7
A variational inequality-based formulation of the frictional contact law with a??non-associated sliding rule, European Journal of Mechanics - A/Solids, vol.21, issue.1, pp.49-59, 2002. ,
DOI : 10.1016/S0997-7538(01)01183-4
URL : https://hal.archives-ouvertes.fr/hal-00140254
Lagrangian mechanics of overparameterized systems, Nonlinear Dynamics, vol.63, issue.1, pp.201-212, 2011. ,
DOI : 10.1016/S0021-8928(99)00005-2
Singularities in the dynamics of systems with non-ideal constraints, Journal of Applied Mathematics and Mechanics, vol.67, issue.2, pp.185-192, 2003. ,
DOI : 10.1016/S0021-8928(03)90004-9
Local convergence of the method of multipliers for variational and optimization problems under the noncriticality assumption, Computational Optimization and Applications, vol.131, issue.1???2, pp.111-14010, 2014. ,
DOI : 10.1007/s10107-010-0345-y
Operational Space Inertia for Closed-Chain Robotic Systems, Journal of Computational and Nonlinear Dynamics, vol.9, issue.2, p.21015, 2014. ,
DOI : 10.1115/1.4025893
Efficient Solution of Maggi???s Equations, Journal of Computational and Nonlinear Dynamics, vol.7, issue.2, p.21003, 2012. ,
DOI : 10.1115/1.4005238
Multibody dynamics with redundant constraints and singular mass matrix: existence, uniqueness, and determination of solutions for accelerations and constraints forces, Multibody Syst. Dyn, vol.30, issue.3, pp.311-34110, 2013. ,
SciPy: open source scientific tools for Python URL http://www.scipy.org/. [Online, pp.2016-2021, 2001. ,
The Theory of Matrices, 1985. ,
Review of Classical Approaches for Constraint Enforcement in Multibody Systems, Journal of Computational and Nonlinear Dynamics, vol.3, issue.1, p.11004, 2008. ,
DOI : 10.1115/1.2803257
Periodic motion and bifurcations induced by the Painlev?? paradox, European Journal of Mechanics - A/Solids, vol.21, issue.5, pp.869-896, 2002. ,
DOI : 10.1016/S0997-7538(02)01231-7
URL : http://www.zfm.ethz.ch/~leine/papers/Leine %26 Brogliato %26 Nijmeijer - Periodic Motion and Bifurcations Induced by the Painleve Paradox.pdf
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
DOI : 10.1007/978-3-540-76975-0
Coulomb Friction in Two-Dimensional Rigid Body Systems, ZAMM - Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.5, issue.12, pp.605-615, 1981. ,
DOI : 10.1002/zamm.19810611202
Mechanical Systems of Rigid Bodies Subject to Unilateral Constraints, SIAM Journal on Applied Mathematics, vol.42, issue.2, pp.281-296, 1982. ,
DOI : 10.1137/0142022
Solving constrained mechanical systems by the family of Newmark and ??-methods, ZAMM, vol.158, issue.13, pp.772-784, 2006. ,
DOI : 10.1002/zamm.200610285
A time-stepping method for stiff multibody dynamics with contact and friction, International Journal for Numerical Methods in Engineering, vol.10, issue.7, pp.753-784, 2002. ,
DOI : 10.1007/978-1-4612-1394-9
Right-hand solutions of the differential equations of dynamics for mechanical systems with sliding friction, Journal of Applied Mathematics and Mechanics, vol.59, issue.6, pp.837-844, 1995. ,
DOI : 10.1016/0021-8928(95)00116-6
The theory of differential equations which arise in the dynamics of a system of rigid bodies with Coulomb friction, Monogr. Acad. Nonlinear Sci., Adv. Nonlinear Sci, vol.2, pp.16-106, 2008. ,
Les liaisons unilatérales et le principe de Gauss, C. R. Acad. Sci, vol.256, issue.4, pp.871-874, 1963. ,
Quadratic Programming in Mechanics: Dynamics of One-Sided Constraints, SIAM Journal on Control, vol.4, issue.1, pp.153-158, 1966. ,
DOI : 10.1137/0304014
URL : https://hal.archives-ouvertes.fr/hal-01379713
Partitioned half-explicit Runge-Kutta methods for differential-algebraic systems of index 2, Computing, vol.66, issue.1, pp.43-61, 1997. ,
A Discussion of Low-Order Numerical Integration Formulas for Rigid and Flexible Multibody Dynamics, Journal of Computational and Nonlinear Dynamics, vol.4, issue.2, p.21008, 2009. ,
DOI : 10.1115/1.3079784
Leçons sur le Frottement, 1895. ,
Complementarity formulations and existence of solutions of dynamic multi-rigid-body contact problems with coulomb friction, Mathematical Programming, vol.14, issue.2, pp.199-226, 1996. ,
DOI : 10.1007/BFb0120929
A complementarity approach to a quasistatic multi-rigid-body contact problem, Computational Optimization and Applications, vol.11, issue.2, pp.139-154, 1996. ,
DOI : 10.1109/70.370504
URL : http://www.cs.tamu.edu/faculty/trink/Papers/coap95PangTrinkLo.ps.Z
On non-smooth multibody dynamics, Proc. Inst, pp.147-177, 2012. ,
DOI : 10.1016/S0921-8890(96)00043-7
Convex Analysis, pp.10-1142, 1970. ,
A Penalty Formulation for Dynamics Analysis of Redundant Mechanical Systems, Journal of Computational and Nonlinear Dynamics, vol.6, issue.2, p.21008, 2011. ,
DOI : 10.1115/1.4002510
New Inequality and Functional for Contact with Friction: The Implicit Standard Material Approach???, Mechanics of Structures and Machines, vol.273, issue.3, pp.301-325, 1991. ,
DOI : 10.1016/0045-7949(80)90146-7
Complementarity modeling of hybrid systems, IEEE Transactions on Automatic Control, vol.43, issue.4, pp.483-490, 1998. ,
DOI : 10.1109/9.664151
Euler parameters kinetic singularity, Proc. Inst, pp.10-1177, 2014. ,
DOI : 10.1007/978-3-642-86464-3
Computational Flexible Multibody Dynamics. A Differential-Algebraic Approach Differential-Algebraic Equations Forum, 2013. ,
DOI : 10.1007/978-3-642-35158-7
Lie-group integration method for constrained multibody systems in state space, Multibody System Dynamics, vol.357, issue.1???2, pp.275-30510, 2015. ,
DOI : 10.1098/rsta.1999.0360
Analytical Dynamics: A New Approach, 1996. ,
DOI : 10.1017/CBO9780511665479
Explicit equations of motion for constrained mechanical systems with singular mass matrices and applications to multi-body dynamics, Proc. R. Soc. Lond. A 462, pp.2097-2117, 2006. ,
DOI : 10.1098/rspa.2006.1662
URL : https://hal.archives-ouvertes.fr/hal-01395968
Equations of motion for general constrained systems in Lagrangian mechanics, Acta Mechanica, vol.36, issue.1-2, pp.111-129, 2010. ,
DOI : 10.1115/1.3260722
URL : https://hal.archives-ouvertes.fr/hal-01395969
Joint reactions in rigid body mechanisms with dependent constraints, Mechanism and Machine Theory, vol.44, issue.12, pp.2265-2278, 2009. ,
DOI : 10.1016/j.mechmachtheory.2009.07.008
Comparison of Selected Methods of Handling Redundant Constraints in Multibody Systems Simulations, Journal of Computational and Nonlinear Dynamics, vol.8, issue.2, p.210007, 2013. ,
DOI : 10.1115/1.4006958
Solvability of reactions in rigid multibody systems with redundant nonholonomic constraints, Multibody System Dynamics, vol.8, issue.2, pp.153-171, 2013. ,
