Fast Mixing with Quantum Walks vs. Classical Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2017
Quantum walks have been linked to acceleration in various information processing tasks, and proposed as a possible model for quantum-enhanced behavior in biological systems. These links and acceleration claims have been made with various levels of detail. Here we consider discrete-time quantum walks, and focus on the task of mixing, i.e., distributing the state over a graph. Previous papers have observed that the so-called coined quantum walks can accelerate mixing on certain graphs with respect to the optimal classical Markov chain. We here show that the same speedup can be attained with a classical process, if a similar classical coin is added. We establish a precise correspondence between the mixing performance of quantum walks and such " lifted walks " for all (finite) graphs, and thereby improve known bounds on quantum walk mixing time. We conclude that the advantage of quantum walks with respect to classical processes is not in the mixing speed of the optimal design. However, a notable quantum advantage might reside in the fact that the mixing speed obtained with suboptimal designs, due to for instance limited graph knowledge, appears to be generically faster.
Final-QIP-abstract.pdf (204.44 Ko) Télécharger le fichier
hal-01395592 , version 1 (11-11-2016)
  • HAL Id : hal-01395592 , version 1
Simon Apers, Alain Sarlette, Francesco Ticozzi. Fast Mixing with Quantum Walks vs. Classical Processes. Quantum Information Processing (QIP) 2017, Jan 2017, Seattle, United States. ⟨hal-01395592⟩
386 Consultations
344 Téléchargements
