http://clang.llvm.org 2015. The LLVM Compiler Infrastructure. (Feb. 2015) http://llvm.org Vagelis Bebelis, Pascal Fradet, Alain Girault, and Bruno Lavigueur. 2013a. A Framework to Schedule Parametric Dataflow Applications on Many-Core Platforms, 17th workshop on Compilers for Parallel Computing, 2015. ,
BPDF: A statically analyzable dataflow model with integer and boolean parameters, 2013 Proceedings of the International Conference on Embedded Software (EMSOFT), pp.1-10, 2013. ,
DOI : 10.1109/EMSOFT.2013.6658581
URL : https://hal.archives-ouvertes.fr/hal-00923672
Liveness evaluation of a cyclo-static DataFlow graph, Proceedings of the 50th Annual Design Automation Conference on, DAC '13, 2013. ,
DOI : 10.1145/2463209.2488736
URL : https://hal.archives-ouvertes.fr/hal-00861992
Analyzing models of computation for software defined radio applications, 2008 International Symposium on System-on-Chip, pp.1-4, 2008. ,
DOI : 10.1109/ISSOC.2008.4694886
Parameterized dataflow modeling for DSP systems, IEEE Transactions on Signal Processing, vol.49, issue.10, pp.2408-2421, 2001. ,
DOI : 10.1109/78.950795
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.9370
Synthesis of embedded software from synchronous dataflow specifications Journal of VLSI signal processing systems for signal, pp.151-166, 1999. ,
Ptolemy: A framework for simulating and prototyping heterogeneous systems, International Journal of Computer Simulation, special issue on Simulation Software Development, issue.4, pp.155-182, 1994. ,
Compiling for reconfigurable computing, Comput. Surveys, vol.42, issue.4, pp.1-65, 2010. ,
Component-based waveform development: the Nucleus tool flow for efficient and portable software defined radio, Analog Integrated Circuits and Signal Processing, vol.93, issue.2, pp.2-3, 2011. ,
DOI : 10.1007/s10470-011-9670-1
A 477mW NoC-based digital baseband for MIMO 4G SDR, 2010 IEEE International Solid-State Circuits Conference, (ISSCC), pp.278-279, 2010. ,
DOI : 10.1109/ISSCC.2010.5433920
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.472.8659
An Open and Reconfigurable Platform for 4G Telecommunication: Concepts and Application, 2009 12th Euromicro Conference on Digital System Design, Architectures, Methods and Tools, pp.449-456, 2009. ,
DOI : 10.1109/DSD.2009.200
A Communication and configuration controller for NoC based reconfigurable data flow architecture, 2009 3rd ACM/IEEE International Symposium on Networks-on-Chip, pp.153-162, 2009. ,
DOI : 10.1109/NOCS.2009.5071463
Modeling staticorder schedules in synchronous dataflow graphs, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.775-780, 2012. ,
Cognitive Radio Programming: Existing Solutions and Open Issues, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00859467
A compilation flow for parametric dataflow, Proceedings of the 2014 International Conference on Compilers, Architecture and Synthesis for Embedded Systems, CASES '14, 2014. ,
DOI : 10.1145/2656106.2656110
URL : https://hal.archives-ouvertes.fr/hal-01048649
Compilation for heterogeneous SoCs : Bridging the gap between software and target-specific mechanisms, Workshop on High Performance Energy Efficient Embedded Systems (HIPEAC), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00936924
SPDF: A schedulable parametric data-flow MoC, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.769-774, 2012. ,
DOI : 10.1109/DATE.2012.6176572
URL : https://hal.archives-ouvertes.fr/hal-00744376
Minimising buffer requirements of synchronous dataflow graphs with model checking, Proceedings of the 42nd annual conference on Design automation , DAC '05, p.819, 2005. ,
DOI : 10.1145/1065579.1065796
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.106.5720
The earlier the better, Proceedings of the 14th international conference on Hybrid systems: computation and control, HSCC '11, pp.23-32, 2011. ,
DOI : 10.1145/1967701.1967707
Liveness and boundedness of synchronous data flow graphs, In Formal Methods in Computer Aided Design, pp.68-75, 2006. ,
Open-source SCA-based core framework and rapid development tools enable softwaredefined radio education and research, IEEE Communications Magazine, vol.47, pp.10-48, 2009. ,
DOI : 10.1109/mcom.2009.5273808
DiplodocusDF, a Domain-Specific Modelling Language for Software Defined Radio Applications, 2012 38th Euromicro Conference on Software Engineering and Advanced Applications, pp.1-8, 2012. ,
DOI : 10.1109/SEAA.2012.36
URL : https://hal.archives-ouvertes.fr/hal-00739847
??C: A Programming Model and Language for Embedded Manycores, Algorithms and Architectures for Parallel Processing -11th International Conference, pp.385-394, 2011. ,
DOI : 10.1007/978-3-642-24650-0_33
Scheduling optimisations for SPIN to minimise buffer requirements in synchronous data flow, International Conference on Formal Methods in Computer-Aided Design (FMCAD), 2008. ,
Just-in-time scheduling techniques for multicore signal processing systems, 2014 IEEE Global Conference on Signal and Information Processing (GlobalSIP), pp.25-29, 2014. ,
DOI : 10.1109/GlobalSIP.2014.7032071
URL : https://hal.archives-ouvertes.fr/hal-01101790
The SPIN model checker: Primer and reference manual, 2004. ,
An improvement in formal verification, International Conference on Formal Description Techniques (FORTE), pp.197-211, 1994. ,
Advances in dataflow programming languages, ACM Computing Surveys, vol.36, issue.1, pp.1-34, 2004. ,
DOI : 10.1145/1013208.1013209
Multi-objective mapping optimization via problem decomposition for many-core systems, 2012 IEEE 10th Symposium on Embedded Systems for Real-time Multimedia, pp.28-37, 2012. ,
DOI : 10.1109/ESTIMedia.2012.6507026
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.304.4210
Phased scheduling of stream programs, Conference on Languages, Compilers, and Tools for Embedded Systems (LCTES), 2003. ,
DOI : 10.1145/780732.780747
Disciplined Multi-core Programming in C, International Conference on Parallel and Distributed Processing Techniques and Applications (PDPTA), 2010. ,
A retargetable parallelprogramming framework for MPSoC, ACM Trans. Des. Autom. Electron. Syst, vol.13, pp.3-4, 2008. ,
Synchronous data flow, Proc. IEEE, pp.1235-1245, 1987. ,
SPEX: A programming language for software defined radio, SDR Forum Technical Conference, pp.13-17, 2006. ,
An efficient technique for analysis of minimal buffer requirements of synchronous dataflow graphs with model checking, Proceedings of the 7th IEEE/ACM international conference on Hardware/software codesign and system synthesis, CODES+ISSS '09, pp.61-70, 2009. ,
DOI : 10.1145/1629435.1629445
Orchestrating stream graphs using model checking, ACM Transactions on Architecture and Code Optimization, vol.10, issue.3, p.19, 2013. ,
DOI : 10.1145/2512435
PinaVM, Proceedings of the tenth ACM international conference on Embedded software, EMSOFT '10, p.79, 2010. ,
DOI : 10.1145/1879021.1879032
URL : https://hal.archives-ouvertes.fr/hal-00495874
SystemC -A modeling platform supporting multiple design, Proc. 14th International Symposium on Systems Synthesis (ISSS), pp.75-80, 2001. ,
Preesm: A dataflow-based rapid prototyping framework for simplifying multicore DSP programming, 2014 6th European Embedded Design in Education and Research Conference (EDERC), pp.36-40, 2014. ,
DOI : 10.1109/EDERC.2014.6924354
URL : https://hal.archives-ouvertes.fr/hal-01059313
Structured Scheduling of Recurrence Equations: Theory and Practice, Proc. of the System Architecture MOdelling and Simulation Workshop, pp.112-134, 2001. ,
DOI : 10.1007/3-540-45874-3_7
Digital Front-End in Wireless Communications and Broadcasting Chapter Programming models and implementation platforms for software defined radio configuration, pp.650-670, 2011. ,
Mode-controlled dataflow based modeling & analysis of a 4g-lte receiver, Proceedings of the conference on Design, p.212, 2014. ,
Analyzing synchronous dataflow scenarios for dynamic software-defined radio applications, 2011 International Symposium on System on Chip (SoC), pp.14-21, 2011. ,
DOI : 10.1109/ISSOC.2011.6089222
SDF3: SDF For Free, International Conference on Application of Concurrency to System Design (ACSD). IEEE, pp.276-278, 2006. ,
DOI : 10.1109/acsd.2006.23
Scenario-aware dataflow: Modeling, analysis and implementation of dynamic applications, 2011 International Conference on Embedded Computer Systems: Architectures, Modeling and Simulation, pp.404-411, 2011. ,
DOI : 10.1109/SAMOS.2011.6045491
Performance Model Checking Scenario-Aware Dataflow, Proceedings of the International Conference on Formal Modeling and Analysis of Timed Systems (FORMATS), pp.43-59, 2011. ,
DOI : 10.1016/S0166-5316(02)00105-0
Hard-Real-Time Scheduling on a Weakly Programmable Multi-core Processor with Application to Multi-standard Channel Decoding, 2012 IEEE 18th Real Time and Embedded Technology and Applications Symposium, pp.2012-2030, 2012. ,
DOI : 10.1109/RTAS.2012.32
URL : http://library.tue.nl/csp/dare/LinkToRepository.csp?recordnumber=734283
Aperiodic multiprocessor scheduling for real-time stream processing applications, 2009. ,
SODA: A Low-power Architecture For Software Radio, 33rd International Symposium on Computer Architecture, pp.89-101, 2006. ,
The Next Generation Challenge for Software Defined Radio, Embedded Computer Systems: Architectures, Modeling, and Simulation. Samos, Greece, pp.343-354, 2007. ,
DOI : 10.1007/978-3-540-73625-7_36
URL : http://cccp.eecs.umich.edu/papers/woh-samos07.pdf
Overview of the 3GPP long term evolution physical layer, 2007. ,
