Amplitude Control of an Ultrasonic Vibration for a Tactile Stimulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ASME Transactions on Mechatronics Année : 2016
This paper describes the control in a (d-q) frame of the vibration amplitude of a tactile stimulator based on ultrasonic vibrations. The objective is to combine two control strategies in order to maintain a constant level of vibration amplitude and to excite at the resonance frequency of the system. A new modelling approach is presented to identify the transfer function between inputs and outputs. Then, thanks to an experimental setup, the validation of the new model is performed. Finally, the result of the closed loop control over wide range of disturbing factors is presented.
ARTICLE TOM_FIN_REVIEWD (1).pdf (902.3 Ko) Télécharger le fichier
hal-01396831 , version 1 (26-09-2018)
Wael Ben Messaoud, Frédéric Giraud, Betty Lemaire-Semail, Michel Amberg, Marie-Ange Bueno. Amplitude Control of an Ultrasonic Vibration for a Tactile Stimulator. IEEE/ASME Transactions on Mechatronics, 2016, 21 (3), pp.1692 - 1701. ⟨10.1109/TMECH.2016.2535300⟩. ⟨hal-01396831⟩
260 Consultations
414 Téléchargements
