Towards Semantic Mashup Tools for Big Data Analysis
Big Data is generally characterized by three V’s: volume, velocity, and variety. For the Semantic Web community, the variety dimension could be the most appropriate and interesting aspect to contribute in. Since the real-world use of Big Data is for data analytics purposes of knowledge workers in different domains, we can consider mashup approach as an effective tool to create user-generated solution based on available private/public resources. This paper gives brief overview and comparison of some semantic mashup tools which can be employed to mash up various data sources in heterogenous data format.
