Efficient Variant of Rainbow without Triangular Matrix Representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multivariate Public Key Cryptosystems (MPKC) is one of candidates for post-quantum cryptography. Rainbow is an MPKC digital signature scheme, with relatively efficient encryption and decryption processes. However, the size of MPKC key is substantially larger than that of an RSA cryptosystem for the same security level. In this paper, we propose a variant of Rainbow that has a smaller secret key. The smaller secret key is to the result of a different description of the quadratic polynomials appearing in the secret key from that of the original Rainbow. In addition, our scheme improves the efficiency of the Rainbow’s signature generation. In particular, the secret key is reduced in size by about 40% and the signature generation is sped up by about 30% at the security level of 100 bits.
978-3-642-55032-4_55_Chapter.pdf (93.55 Ko) Télécharger le fichier
hal-01397267 , version 1 (15-11-2016)
Paternité
Takanori Yasuda, Tsuyoshi Takagi, Kouichi Sakurai. Efficient Variant of Rainbow without Triangular Matrix Representation. 2nd Information and Communication Technology - EurAsia Conference (ICT-EurAsia), Apr 2014, Bali, Indonesia. pp.532-541, ⟨10.1007/978-3-642-55032-4_55⟩. ⟨hal-01397267⟩
51 Consultations
158 Téléchargements
