CIDANE: comprehensive isoform discovery and abundance estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Genome Biology Année : 2016
We present CIDANE, a novel framework for genome-based transcript reconstruction and quantification from RNA-seq reads. CIDANE assembles transcripts efficiently with significantly higher sensitivity and precision than existing tools. Its algorithmic core not only reconstructs transcripts ab initio, but also allows the use of the growing annotation of known splice sites, transcription start and end sites, or full-length transcripts, which are available for most model organisms. CIDANE supports the integrated analysis of RNA-seq and additional gene-boundary data and recovers splice junctions that are invisible to other methods. CIDANE is available at
cidane.pdf (1.74 Mo) Télécharger le fichier
hal-01397539 , version 1 (16-11-2016)
hal-01397539 , version 2 (30-05-2017)
Stefan Canzar, Sandro Andreotti, David W Weese, Knut Reinert, Gunnar W Klau. CIDANE: comprehensive isoform discovery and abundance estimation. Genome Biology, 2016, 17, pp.16. ⟨10.1186/s13059-015-0865-0⟩. ⟨hal-01397539v2⟩
268 Consultations
302 Téléchargements
