Frontiers of aerothermodynamics. In RTO-EN-AVT-162 -Non- Equilibrium Gas Dynamics From Physical Models to Hypersonic Flights, 2008. ,
Quantication of uncertainty in ow simulations using probabilistic methods. In RTO-EN-AVT-162 -Non-Equilibrium Gas Dynamics From Physical Models to Hypersonic Flights, 2008. ,
Uncertainty quantification of a graphite nitridation experiment using a Bayesian approach, Experimental Thermal and Fluid Science, vol.35, issue.8, pp.1588-1599, 2011. ,
DOI : 10.1016/j.expthermflusci.2011.07.010
Uncertainty-quantification analysis of the effects of residual impurities on hydrogen???oxygen ignition in shock tubes, Combustion and Flame, vol.161, issue.1, pp.1-15, 2014. ,
DOI : 10.1016/j.combustflame.2013.08.012
Uncertainty quantification and robust predictive system analysis for high temperature kinetics of hcn/o2/ar mixture, Chemical Physics, vol.475, pp.136-152, 2016. ,
Characterization of gas/surface interactions for ceramic matrix composites in high enthalpy, low pressure air flow, Materials Chemistry and Physics, vol.134, issue.2-3, pp.597-607, 2012. ,
DOI : 10.1016/j.matchemphys.2012.03.036
Conditions of simulation of stagnation point heat transfer from a high-enthalpy ow. Fluid Dynamics, pp.131-137, 1993. ,
Accurate and Efficient Modelling of High Temperature Nonequilibrium Air Flows, 2006. ,
Flight Extrapolation of Plasma Wind Tunnel Stagnation Region Flowfield, Journal of Thermophysics and Heat Transfer, vol.20, issue.3, pp.493-499, 2006. ,
DOI : 10.2514/1.17185
Theory of Stagnation Point Heat Transfer in Dissociated Air, Journal of the Aerospace Sciences, vol.25, issue.2, pp.73-85, 1958. ,
DOI : 10.2514/8.7517
On Catalytic Recombination Rates in Hypersonic Stagnation Heat Transfer, Journal of Jet Propulsion, vol.28, issue.11, pp.737-745, 1958. ,
DOI : 10.2514/8.7444
Oxidation of ZrB2-SiC Ultrahigh-Temperature Ceramic Composites in Dissociated Air, Journal of Thermophysics and Heat Transfer, vol.23, issue.2, pp.267-278, 2009. ,
DOI : 10.2514/1.39970
Investigation of Freestream Plasma Flow Produced by Inductively Coupled Plasma Wind Tunnel, Journal of Thermophysics and Heat Transfer, vol.28, issue.3, pp.381-393, 2014. ,
DOI : 10.2514/1.T4199
Catalytic recombination of nitrogen and oxygen on high-temperature reusable surface insulation, 15th Thermophysics Conference, 1477. ,
DOI : 10.2514/6.1980-1477
Recombination Coefficients and Spectral Emissivity of Silicon Carbide-Based Thermal Protection Materials, Journal of Thermophysics and Heat Transfer, vol.19, issue.4, pp.566-571, 2005. ,
DOI : 10.2514/1.12814
Recent catalysis measurements at IRS, Advances in Space Research, vol.56, issue.4, pp.742-765, 2015. ,
DOI : 10.1016/j.asr.2015.04.028
Surface Catalyzed Reaction Efficiencies in Oxygen Plasmas from Laser-Induced Fluorescence Measurements, Journal of Thermophysics and Heat Transfer, pp.1-11, 2016. ,
DOI : 10.2514/1.T4923
Investigation of Evidence Theory for Engineering Applications, 43rd AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics, and Materials Conference, pp.2002-1569, 2002. ,
DOI : 10.2514/6.2002-1569
Comparison of Enthalpy Determination Methods for an Arc-Jet Facility, Journal of Thermophysics and Heat Transfer, vol.20, issue.4, pp.672-679, 2006. ,
DOI : 10.2514/1.15744
Surface Catalysis and Oxidation on Stagnation Point Heat Flux Measurements in High Enthalpy Arc Jets, 44th AIAA Thermophysics Conference, pp.2013-3138, 2013. ,
DOI : 10.2514/6.2013-3138
Recombination of atoms at surfaces An effusion method applied to oxygen atom recombination, Journal of Catalysis, vol.7, issue.4, pp.324-341, 1967. ,
DOI : 10.1016/0021-9517(67)90161-3
Experimental Study of Flow Parameters and MHD Generator Models at High Frequency Plasmatron, 15 th International Conderence on MHD Energy Conversion and 6 th Workshop on Magnetoplasma Aerodynamics, 2005. ,
Oxygen Catalytic Recombination on Copper Oxide in Tertiary Gas Mixtures, Journal of Spacecraft and Rockets, vol.50, issue.3, pp.540-555, 2013. ,
DOI : 10.2514/1.A32312
Aerothermochemistry characterization of thermal protection systems, 2012. ,
Thermodynamic and transport properties for inductive plasma modeling, Journal of Thermophysics and Heat Transfer, vol.13, p.46412, 1999. ,
Transport properties of partially ionized and unmagnetized plasmas, Phys. Rev. E, vol.70, p.46412, 2004. ,
Theoretical and Experimental Studies of Reentry Plasmas, Contractor Report, vol.2232, p.14221, 1973. ,
Chemically Reacting Nonequilibrium Boundary Layer Advances in Heat Transfer, pp.109-270, 1965. ,
DOI : 10.1016/s0065-2717(08)70262-4
Nitric oxide production from surface recombination of oxygen and nitrogen atoms, Journal of Thermophysics and Heat Transfer, vol.22, issue.2, pp.178-186, 2008. ,
Direct detection of no produced by high-temperature surface-catalyzed atom recombination, Journal of Thermophysics and Heat Transfer, vol.24, issue.3, 2010. ,
Surface Chemistry in Non-Equilibrium Flows, Progress in Astronautics and Aeronautics, pp.239-327, 2015. ,
DOI : 10.2514/5.9781624103292.0239.0328
Analysis of non-equilibrium phenomena in inductively coupled plasma generators, Physics of Plasmas, vol.23, issue.7, p.73512, 1994. ,
DOI : 10.1063/1.4958326
The Wiener--Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
DOI : 10.1137/S1064827501387826
Spectral Methods for Uncertainty Quantification . Scientific Computation, 2010. ,
Global sensitivity analysis for stochastic collocation expansion, Proceedings of the 51st AIAA/ASME/ASCE/AHS/ASC Structures, Structural Dynamics, and Materials Conference, 2010. ,
DOI : 10.2514/6.2010-2922
A method for determining catalytic efficiency of surfaces, 1967. ,
