Dynamic Topology Extraction in Cloud Infrastructures
To determine the threat exposure of a virtualized environment, attack graphs generation, coupled to a risk-based assessment can be used. The first roadblock to lift to that end is the extraction of the topology. We will present in this paper the stategy we intend to use to obtain a near real-time view of the connectivity existing in a virtual infrastructure .
