Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Stability results for the parameter identification inverse problem in cardiac electrophysiology
Abstract : In this paper we prove a stability estimate of the parameter identification problem in cardiac electrophysiology modeling. We use the monodomain model which is a reaction diffusion parabolic equation where the reaction term is obtained by solving an ordinary differential equation. We are interested in proving the stability of the identification of the parameter τ in which is the parameter that multiplies the cubic term in the reaction term. The proof of the result is based on a new Carleman-type estimate for both the PDE and ODE problems. As a consequence of the stability result we prove the uniqueness of the parameter τ in giving some observations of both state variables at a given time t 0 in the whole domain and the PDE variable in a non empty open subset w 0 of the domain.
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01399373
Contributor : Nejib Zemzemi Connect in order to contact the contributor
Submitted on : Friday, November 18, 2016 - 4:55:10 PM
Last modification on : Thursday, January 20, 2022 - 5:31:34 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 8:33:29 AM
File
Paper-Mahjoub-Moncef-soumissio...
Identifiers
Collections
Citation
Jamila Lassoued, Moncef Mahjoub, Nejib Zemzemi. Stability results for the parameter identification inverse problem in cardiac electrophysiology. Inverse Problems, IOP Publishing, 2016, 32 (11), pp.1-31. ⟨10.1088/0266-5611/32/11/115002⟩. ⟨hal-01399373⟩
Share
Metrics
Record views
223
Files downloads
256
