Detecting Version Number Attacks in RPL-based Networks using a Distributed Monitoring Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anthéa Mayzaud
Rémi Badonnel
  • Fonction : Auteur
  • PersonId : 947216
Isabelle Chrisment
The concept of Internet of Things involves the deployment of Low power and Lossy Networks (LLN) allowing communications among pervasive devices such as embedded sensors. The IETF designed the Routing Protocol for Low power and Lossy Networks (RPL) for supporting these constrained networks. Keeping in mind the different requirements of such networks, the protocol supports multiple routing topologies, called DODAGs, built using different objective functions, so as to optimize routing based on several metrics. A DODAG versioning system is incorporated into RPL in order to ensure an optimized topology. However, an attacker can exploit this mechanism to damage the network and reduce its lifetime. In this paper we propose a detection strategy based on a distributed monitoring architecture with dedicated algorithms that is able to identify malicious nodes performing such attacks in RPL- based environments. The performance of this solution is evaluated through extensive experiments and its scalability is quantified considering a monitoring node placement method.
Fichier non déposé
hal-01399432 , version 1 (18-11-2016)
  • HAL Id : hal-01399432 , version 1
Anthéa Mayzaud, Rémi Badonnel, Isabelle Chrisment. Detecting Version Number Attacks in RPL-based Networks using a Distributed Monitoring Architecture. IEEE/IFIP/In Assoc. with ACM SIGCOMM International Conference on Network and Service Management (CNSM'16), Oct 2016, Montreal, Canada. pp.9. ⟨hal-01399432⟩
300 Consultations
0 Téléchargements
