Robust selection of parametric motion models in image sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Parametric motion models are commonly used in image sequence analysis for different tasks. A robust estimation framework is usually required to reliably compute the motion model. The choice of the right model is also important. However, dealing simultaneously with both issues remains an open question. We propose a robust motion model selection method with two variants, which relies on the Fisher test. We also derive an interpretation of it as a robust Mallows' Cp criterion. The resulting criterion is straightforward to compute. We have conducted a comparative experimental evaluation on different image sequences demonstrating the interest and the efficiency of the proposed method.
icip16_paper1240_final.pdf (537.84 Ko) Télécharger le fichier
hal-01400895 , version 1 (22-11-2016)
Patrick Bouthemy, Bertha Mayela Toledo Acosta, Bernard Delyon. Robust selection of parametric motion models in image sequences. 2016 IEEE International Conference on Image Processing (ICIP), Oct 2016, Phoenix, United States. pp.3743 - 3747, ⟨10.1109/ICIP.2016.7533059⟩. ⟨hal-01400895⟩
163 Consultations
221 Téléchargements
