A Verified SAT Solver Framework with Learn, Forget, Restart, and Incrementality (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We developed a formal framework for CDCL (conflict-driven clause learning) in Isabelle/HOL. Through a chain of refinements, an abstract CDCL calculus is connected to a SAT solver expressed in a functional programming language, with total correctness guarantees. The framework offers a convenient way to prove metatheorems and experiment with variants. Compared with earlier SAT solver verifications, the main novelties are the inclusion of rules for forget, restart, and incremental solving and the application of refinement.
sat_abs.pdf (66.29 Ko) Télécharger le fichier
hal-01401807 , version 1 (23-11-2016)
  • HAL Id : hal-01401807 , version 1
Jasmin Christian Blanchette, Mathias Fleury, Christoph Weidenbach. A Verified SAT Solver Framework with Learn, Forget, Restart, and Incrementality (Extended Abstract). Isabelle Workshop 2016, Aug 2016, Nancy, France. ⟨hal-01401807⟩
145 Consultations
27 Téléchargements
