Conference papers
Treewidth Computation and Kernelization in the Parallel External Memory Model
Riko Jacob 1 Tobias Lieber 1 Matthias Mnich 2
2 Cluster of Excellence Multimodal Computing and Interaction
Saarland University [Saarbrücken], Max Planck Institute for Informatics [Saarbrücken], DFKI - Deutsches Forschungszentrum für Künstliche Intelligenz GmbH = German Research Center for Artificial Intelligence, Max Planck Institute for Software Systems
Abstract : We present a randomized algorithm which computes, for any fixed k, a tree decomposition of width at most k of any input graph. We analyze it in the parallel external memory (PEM) model that measures efficiency by counting the number of cache misses on a multi-CPU private cache shared memory machine. Our algorithm has sorting complexity, which we prove to be optimal for a large parameter range.  We use this algorithm as part of a PEM-efficient kernelization algorithm. Kernelization is a technique for preprocessing instances of size n of NP-hard problems with a structural parameter κ by compressing them efficiently to a kernel, an equivalent instance of size at most g(κ). An optimal solution to the original instance can then be recovered efficiently from an optimal solution to the kernel. Our main results here is an adaption of the linear-time randomized protrusion replacement algorithm by Fomin et al. (FOCS 2012). In particular, we obtain efficient randomized parallel algorithms to compute linear kernels in the PEM model for all separable contraction-bidimensional problems with finite integer index (FII) on apex minor-free graphs, and for all treewidth-bounding graph problems with FII on topological minor-free graphs.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01402030
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, November 24, 2016 - 10:48:38 AM
Last modification on : Thursday, May 27, 2021 - 1:54:06 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 5:00:11 AM
File
978-3-662-44602-7_7_Chapter.pd...
Identifiers
Citation
Riko Jacob, Tobias Lieber, Matthias Mnich. Treewidth Computation and Kernelization in the Parallel External Memory Model. 8th IFIP International Conference on Theoretical Computer Science (TCS), Sep 2014, Rome, Italy. pp.78-89, ⟨10.1007/978-3-662-44602-7_7⟩. ⟨hal-01402030⟩
Share
Metrics
Record views
45
Files downloads
72
