A certified numerical algorithm for the topology of resultant and discriminant curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2016
Let C be a real plane algebraic curve defined by the resultant of two polynomials (resp. by the discriminant of a polynomial). Geometrically such a curve is the projection of the intersection of the surfaces $P(x, y, z) = Q(x, y, z) = 0 (resp. P(x, y, z) = ∂P ∂z (x, y, z) = 0)$, and generically its singularities are nodes (resp. nodes and ordinary cusps). State-of-the-art numerical algorithms compute the topology of smooth curves but usually fail to certify the topology of singular ones. The main challenge is to find practical numerical criteria that guarantee the existence and the uniqueness of a singularity inside a given box B, while ensuring that B does not contain any closed loop of C. We solve this problem by first providing a square deflation system, based on subresultants, that can be used to certify numerically whether B contains a unique singularity p or not. Then we introduce a numeric adaptive separation criterion based on interval arithmetic to ensure that the topology of C in B is homeomorphic to the local topology at p. Our algorithms are implemented and experiments show their efficiency compared to state-of-the-art symbolic or homotopic methods.
topo_res_disc2.pdf (365.52 Ko) Télécharger le fichier
hal-01402194 , version 1 (24-11-2016)
Rémi Imbach, Guillaume Moroz, Marc Pouget. A certified numerical algorithm for the topology of resultant and discriminant curves. Journal of Symbolic Computation, 2016, 80, Part 2, pp.285--306. ⟨10.1016/j.jsc.2016.03.011⟩. ⟨hal-01402194⟩
325 Consultations
321 Téléchargements
