Certifying solutions to overdetermined and singular polynomial systems over Q, 2014. ,
Topology and arrangement computation of semi-algebraic planar curves, Computer Aided Geometric Design, vol.25, issue.8, pp.631-651, 2008. ,
DOI : 10.1016/j.cagd.2008.06.009
URL : https://hal.archives-ouvertes.fr/inria-00343110
Bertini: Software for numerical algebraic geometry, 2013. ,
Robust Certified Numerical Homotopy Tracking, Foundations of Computational Mathematics, vol.25, issue.2, pp.1-43, 2013. ,
DOI : 10.1007/s10208-013-9143-2
Solving bivariate algebraic systems and topology of plane curves. Theses, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-00979707
New bivariate system solver and topology of algebraic curves Complete subdivision algorithms ii: Isotopic meshing of singular algebraic curves, 27th European Workshop on Computational Geometry -EuroCG, pp.131-152, 2011. ,
Explicit factors of some iterated resultants and discriminants, Mathematics of Computation, vol.78, issue.265, pp.345-386, 2009. ,
DOI : 10.1090/S0025-5718-08-02111-X
On the Topology of Real Algebraic Plane Curves, Mathematics in Computer Science, vol.41, issue.9, pp.113-137, 2010. ,
DOI : 10.1007/s11786-010-0044-3
URL : https://hal.archives-ouvertes.fr/inria-00517175
Computing the topology of a real algebraic plane curve whose defining equations are available only ???by values???, Computer Aided Geometric Design, vol.30, issue.7, pp.675-706, 2013. ,
DOI : 10.1016/j.cagd.2013.04.003
Using Algebraic Geometry, 2005. ,
DOI : 10.1007/978-1-4757-6911-1
Points fixes, zéros et la méthode de Newton, Mathématiques et Applications, 2006. ,
A numerical approach to compute the topology of the Apparent Contour of a smooth mapping from <mml:math altimg="si17.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mi mathvariant="double-struck">R</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msup></mml:math> to <mml:math altimg="si18.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msup><mml:mrow><mml:mi mathvariant="double-struck">R</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msup></mml:math>, Journal of Computational and Applied Mathematics, vol.271, pp.267-284, 2014. ,
DOI : 10.1016/j.cam.2014.03.032
On the complexity of solving a bivariate polynomial system, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.154-161, 2012. ,
DOI : 10.1145/2442829.2442854
On Location and Approximation of Clusters of Zeros: Case of Embedding Dimension One, Foundations of Computational Mathematics, vol.7, issue.1, pp.1-58, 2007. ,
DOI : 10.1007/s10208-004-0159-5
URL : https://hal.archives-ouvertes.fr/hal-00186739
Algorithm 921, ACM Transactions on Mathematical Software, vol.38, issue.4, pp.1-28, 2012. ,
DOI : 10.1145/2331130.2331136
Singularites Rationnelles Du Resultant, Proc. Summer Meeting, pp.183-213, 1978. ,
DOI : 10.1007/BFb0066645
An elementary approach to subresultants theory, Journal of Symbolic Computation, vol.35, issue.3, pp.281-292, 2003. ,
DOI : 10.1016/S0747-7171(02)00135-9
URL : http://doi.org/10.1016/s0747-7171(02)00135-9
Rigorous global search: continuous problems. Nonconvex optimization and its applications, 1996. ,
DOI : 10.1007/978-1-4757-2495-0
Empirical Evaluation of Innovations in Interval Branch and Bound Algorithms for Nonlinear Systems, SIAM Journal on Scientific Computing, vol.18, issue.2, pp.574-594, 1997. ,
DOI : 10.1137/S1064827594266131
Newton-algorithms for evaluation of roots with error bounds, Computing, vol.47, issue.3, pp.187-201, 1969. ,
DOI : 10.1007/BF02234767
HOM4PS-2.0: a software package for solving polynomial systems by the polyhedral homotopy continuation method, Computing, vol.38, issue.6, pp.109-133, 2008. ,
DOI : 10.1007/s00607-008-0015-6
Newton's method with deflation for isolated singularities of polynomial systems, Theoretical Computer Science, vol.359, issue.1-3, pp.111-122, 2006. ,
DOI : 10.1016/j.tcs.2006.02.018
Subdivision methods for 2d and 3d implicit curves. In: Geometric modeling and algebraic geometry, pp.171-186, 2008. ,
DOI : 10.1007/978-3-540-72185-7_11
URL : https://hal.archives-ouvertes.fr/inria-00130216
Adaptive Isotopic Approximation of Nonsingular Curves: the Parameterizability and Nonlocal Isotopy Approach, Discrete & Computational Geometry, vol.26, issue.2, pp.760-795, 2011. ,
DOI : 10.1007/s00454-011-9345-9
Marching cubes: A high resolution 3D surface construction algorithm, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.163-169, 1987. ,
DOI : 10.1145/37402.37422
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.132.3930
Finding all real points of a complex curve, In: Algebra, geometry and their interactions. Contemp. Math. Amer. Math. Soc, vol.448448, pp.183-20508665, 2007. ,
DOI : 10.1090/conm/448/08665
Deflation and certified isolation of singular zeros of polynomial systems, Proceedings of the 36th international symposium on Symbolic and algebraic computation, ISSAC '11, pp.249-256, 2011. ,
DOI : 10.1145/1993886.1993925
URL : https://hal.archives-ouvertes.fr/inria-00556021
Certified Parallelotope Continuation for One-Manifolds, SIAM Journal on Numerical Analysis, vol.51, issue.6, pp.3373-3401, 2013. ,
DOI : 10.1137/130906544
URL : https://hal.archives-ouvertes.fr/hal-01408525
Safe Starting Regions for Iterative Methods, SIAM Journal on Numerical Analysis, vol.14, issue.6, pp.1051-1065, 1977. ,
DOI : 10.1137/0714072
Fast polynomial evaluation and composition, Inria Nancy -Grand Est, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00846961
Algebraic Issues in Computational Geometry, Effective Computational Geometry for Curves and Surfaces. Mathematics and Visualization, pp.117-155, 2006. ,
DOI : 10.1007/978-3-540-33259-6_3
Computing the Branches, Singularity Trace, and Critical Points of Single Degree-of-Freedom, Closed-Loop Linkages, Journal of Mechanisms and Robotics, vol.6, issue.1, 2013. ,
DOI : 10.1115/1.4025752
Interval methods for systems of equations URL http://www.loc.gov/catdir/toc/cam041/89070812 Deflation algorithm for the multiple roots of a system of nonlinear equations, Journal of Mathematical Analysis and Applications, vol.96, issue.2, pp.463-479, 1983. ,
Non-linear computational geometry for planar algebraic curves. Theses, Université Nancy II. URL https, 2010. ,
Isotopic approximation of implicit curves and surfaces, Proceedings of the 2004 Eurographics/ACM SIGGRAPH symposium on Geometry processing , SGP '04, pp.245-254, 2004. ,
DOI : 10.1145/1057432.1057465
Topology of planar singular curves resultant of two trivariate polynomials. Bachelor's Thesis. URL http, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00927768
Motivations for an Arbitrary Precision Interval Arithmetic and the MPFI Library, Reliable Computing, vol.2, issue.3, pp.1-16, 2005. ,
DOI : 10.1007/s11155-005-6891-y
URL : https://hal.archives-ouvertes.fr/inria-00544998
Efficient isolation of polynomial's real roots, Journal of Computational and Applied Mathematics, vol.162, issue.1, pp.33-50, 2003. ,
DOI : 10.1016/j.cam.2003.08.015
SOLVING ALGEBRAIC PROBLEMS WITH HIGH ACCURACY, pp.51-120, 1983. ,
DOI : 10.1016/B978-0-12-428660-3.50010-0
Exclusion Regions for Systems of Equations, SIAM Journal on Numerical Analysis, vol.42, issue.1, pp.383-408, 2005. ,
DOI : 10.1137/S0036142902418898
On the exact computation of the topology of real algebraic curves, Proceedings of the twenty-first annual symposium on Computational geometry , SCG '05, pp.107-115, 2005. ,
DOI : 10.1145/1064092.1064111
Interval analysis for computer graphics, Proceedings of the 19th annual conference on Computer graphics and interactive techniques. SIGGRAPH '92, pp.121-130, 1992. ,
DOI : 10.1145/133994.134024
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.7431
Interval methods for bounding the range of polynomials and solving systems of nonlinear equations, 1995. ,
On the number of branches of a $1$-dimensional semianalytic set, Kodai Mathematical Journal, vol.11, issue.1, pp.78-85, 1988. ,
DOI : 10.2996/kmj/1138038822
Reliable homotopy continuation, Tech. rep, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00589948
Homotopies for solving polynomial systems within a bounded domain, Theoretical Computer Science, vol.133, issue.1, pp.165-185, 1994. ,
DOI : 10.1016/0304-3975(94)00064-6
