Access-time aware cache algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most of the caching algorithms are oblivious to requests' timescale, but caching systems are capacity constrained and, in practical cases, the hit rate may be limited by the cache's impossibility to serve requests fast enough. In particular, the hard-disk access time can be the key factor capping cache performances. In this paper, we present a new cache replacement policy that takes advantage of a hierarchical caching architecture , and in particular of access-time difference between memory and disk. Our policy is optimal when requests follow the independent reference model, and significantly reduces the hard-disk load, as shown also by our realistic, trace-driven evaluation.
HAL_version_nov2016.pdf (1.15 Mo) Télécharger le fichier
hal-01402425 , version 1 (24-11-2016)
  • HAL Id : hal-01402425 , version 1
Giovanni Neglia, Damiano Carra, Mingdong Feng, Vaishnav Janardhan, Pietro Michiardi, et al.. Access-time aware cache algorithms. International Teletraffic Congress ITC-28, Sep 2016, Würzburg, Germany. ⟨hal-01402425⟩
119 Consultations
111 Téléchargements
