Variational Image-Based Rendering with Gradient Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multi-view image-based rendering consists in generating a novel view of a scene from a set of source views. In general, this works by first doing a coarse 3D reconstruction of the scene, and then using this reconstruction to establish correspondences between source and target views, followed by blending the warped views to get the final image. Unfortunately, discontinuities in the blending weights, due to scene geometry or camera placement, result in artifacts in the target view. In this paper, we show how to avoid these artifacts by imposing additional constraints on the image gradients of the novel view. We propose a variational framework in which an energy functional is derived and optimized by iteratively solving a linear system. We demonstrate this method on several structured and unstructured multi-view datasets, and show that it numerically outperforms state-of-the-art methods, and eliminates artifacts that result from visibility discontinuities.
ic3d2016.pdf (10.81 Mo) Télécharger le fichier
hal-01402528 , version 1 (24-11-2016)
Grégoire Nieto, Frédéric Devernay, James L. Crowley. Variational Image-Based Rendering with Gradient Constraints. IC3D - 2016 International Conference on 3D Imaging, Dec 2016, Liège, Belgium. pp.1-8, ⟨10.1109/IC3D.2016.7823449⟩. ⟨hal-01402528⟩
487 Consultations
402 Téléchargements
