Johnson-Segalman – Saint-Venant equations for viscoelastic shallow flows in the elastic limit
The shallow-water equations of Saint-Venant, often used to model the long-wave dynamics of free-surface flows driven by inertia and hydrostatic pressure, can be generalized to account for the elongational rheology of non-Newtonian fluids too. We consider here the 4 × 4 shallow-water equations generalized to viscoelastic fluids using the Johnson-Segalman model in the elastic limit (i.e. at infinitely-large Deborah number, when source terms vanish). The system of nonlinear first-order equations is hyperbolic when the slip parameter is small ζ ≤ 1/2 (ζ = 1 is the corotational case and ζ = 0 the upper-convected Maxwell case). Moreover, it is naturally endowed with a mathematical entropy (a physical free-energy). When ζ ≤ 1/2 and for any initial data excluding vacuum, we construct here, when elasticity G > 0 is non-zero, the unique solution to the Riemann problem under Lax admissibility conditions. The standard Saint-Venant case is recovered when G → 0 for small data.
Analyse numérique [math.NA]
