Abstract : The exchanged hypercube, denoted by EH(s, t), is a new interconnection network obtained by systematically removing links from the hypercube, while preserves many appealing properties. This paper addresses the routing and wavelength assignment for realizing exchanged hypercubes communication patterns on linear array WDM optical networks. By using congestion estimation, we derive a lower bound of the minimum number of required wavelengths, and propose an optimal wavelength assignment algorithm that uses 2s + t − 1 + $\lfloor$2t/3$\rfloor$ wavelengths.
https://hal.inria.fr/hal-01403046 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, November 25, 2016 - 2:10:47 PM Last modification on : Thursday, March 5, 2020 - 5:40:21 PM Long-term archiving on: : Tuesday, March 21, 2017 - 1:06:00 PM
yu-Liang Liu. Routing and Wavelength Assignment for Exchanged Hypercubes in Linear Array Optical Networks. 11th IFIP International Conference on Network and Parallel Computing (NPC), Sep 2014, Ilan, Taiwan. pp.1-9, ⟨10.1007/978-3-662-44917-2_1⟩. ⟨hal-01403046⟩
