Abstract : Network bandwidth and hardware technology are developing rapidly, resulting in the vigorous development of the Internet. A concept, cloud computing, uses low-power hosts to achieve high quality service. According to the characteristics of cloud computing, the cloud service providers can support the service applications on the Internet. There are a lot of applications and data centers in the cloud-computing environment, then the loading of storage node is heavier than before. However, data deduplication techniques can greatly reduce the amount of data. Therefore, an integer Bloom Filter based Lightweight Deduplication Mechanism (LDM) under cloud storage is proposed. The proposed LDM can reduce the extra cost that traditional data deduplication technique needed.
https://hal.inria.fr/hal-01403155 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, November 25, 2016 - 2:50:13 PM Last modification on : Monday, March 7, 2022 - 8:20:03 AM Long-term archiving on: : Tuesday, March 21, 2017 - 12:19:04 PM
Kuo-Qin Yan, Yung-Hsiang Su, Hsin-Met Chuan, Shu-Ching Wang, Bowei Chen. Quality of Service Enhancement by Using an Integer Bloom Filter Based Data Deduplication Mechanism in the Cloud Storage Environment. 11th IFIP International Conference on Network and Parallel Computing (NPC), Sep 2014, Ilan, Taiwan. pp.587-590, ⟨10.1007/978-3-662-44917-2_59⟩. ⟨hal-01403155⟩
