Simpira v2: A Family of Efficient Permutations Using the AES Round Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces Simpira, a family of cryptographic permutations that supports inputs of 128*b bits, where b is a positive integer. Its design goal is to achieve high throughput on virtually all modern 64-bit processors, that nowadays already have native instructions for AES. To achieve this goal, Simpira uses only one building block: the AES round function. For b=1, Simpira corresponds to 12-round AES with fixed round keys, whereas for b>=2, Simpira is a Generalized Feistel Structure (GFS) with an F-function that consists of two rounds of AES. We claim that there are no structural distinguishers for Simpira with a complexity below 2^128, and analyze its security against a variety of attacks in this setting. The throughput of Simpira is close to the theoretical optimum, namely, the number of AES rounds in the construction. For example, on the Intel Skylake processor, Simpira has throughput below 1 cycle per byte for b≤4 and b=6. For larger permutations, where moving data in memory has a more pronounced effect, Simpira with b=32 (512 byte inputs) evaluates 732 AES rounds, and performs at 824 cycles (1.61 cycles per byte), which is less than 13% off the theoretical optimum. If the data is stored in interleaved buffers, this overhead is reduced to less than 1%. The Simpira family offers an efficient solution when processing wide blocks, larger than 128 bits, is desired.
simpira.pdf (297.43 Ko) Télécharger le fichier
hal-01403414 , version 1 (25-11-2016)
Copyright (Tous droits réservés)
Shay Gueron, Nicky Mouha. Simpira v2: A Family of Efficient Permutations Using the AES Round Function. Advances in Cryptology - ASIACRYPT 2016, Dec 2016, Hanoi, Vietnam. pp.95-125, ⟨10.1007/978-3-662-53887-6_4⟩. ⟨hal-01403414⟩
Collections
INRIA INRIA2 ANR
228 Consultations
478 Téléchargements
