HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
A Linearithmic Time Algorithm for a Shortest Vector Problem in Compute-and-Forward Design
Jinming Wen 1 Xiao-Wen Chang 2
1 ARIC - Arithmetic and Computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : We propose an algorithm with expected complexity of O(nlogn) arithmetic operations to solve a special shortest vector problem arising in computer-and-forward design, where n is the dimension of the channel vector. This algorithm is more efficient than the best known algorithms with proved complexity.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01403929
Contributor : Gilles Villard Connect in order to contact the contributor
Submitted on : Monday, November 28, 2016 - 10:37:18 AM
Last modification on : Monday, May 16, 2022 - 4:58:02 PM
Links full text
Identifiers
  • HAL Id : hal-01403929, version 1
  • ARXIV : 1602.00169
Collections
Citation
Jinming Wen, Xiao-Wen Chang. A Linearithmic Time Algorithm for a Shortest Vector Problem in Compute-and-Forward Design. 2016. ⟨hal-01403929⟩
Share
Metrics
Record views
79
