HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Metrics-Based Incremental Determinization of Finite Automata
Abstract : Some application domains, including monitoring of active systems in artificial intelligence and model-based mutation testing in software engineering, require determinization of finite automata to be performed incrementally. To this end, an algorithm called Incremental Subset Construction (ISC) was proposed a few years ago. However, this algorithm was recently discovered to be incorrect is some instance problems. The incorrect behavior of ISC originates when the redirection of a transition causes a portion of the automaton to be disconnected from the initial state. This misbehavior is disturbing in two ways: portions of the resulting automaton are disconnected and, as such, useless; moreover, a considerable amount of computation is possibly wasted for processing these disconnected parts. To make ISC sound, a metrics-based technique is proposed in this paper, where the distance between states is exploited in order to guarantee the connection of the automaton, thereby allowing ISC to achieve soundness. Experimental results show that, besides being effective, the proposed technique is efficient too.
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01403984
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, November 28, 2016 - 11:22:24 AM
Last modification on : Thursday, March 5, 2020 - 4:47:09 PM
Long-term archiving on: : Tuesday, March 21, 2017 - 1:23:29 PM
File
978-3-319-10975-6_3_Chapter.pd...
Identifiers
Citation
Sergiu Balan, Gianfranco Lamperti, Michele Scandale. Metrics-Based Incremental Determinization of Finite Automata. International Cross-Domain Conference and Workshop on Availability, Reliability, and Security (CD-ARES), Sep 2014, Fribourg, Switzerland. pp.29-44, ⟨10.1007/978-3-319-10975-6_3⟩. ⟨hal-01403984⟩
Share
Metrics
Record views
70
Files downloads
128
