Abstract : Current software based Content Filtering Systems are too computing intensive in large scale packets payload detection and cannot meet the performance requirements of modern networks. Thus, hardware architectures are desired to speed up the detection process. In this paper, hardware based Conjoint Network Content Filtering System (CNCFS) is proposed to solve the problem. In CNCFS, a TCAM based algorithm named Linking Shared Multi-Match (LSMM) is implemented, which can speed up large scale Multi-Pattern Multi-Matching greatly. Also, this system can also be used in high speed mobile networks which need to deal with the security of fast handover of mobile users. The results of performance evaluation show that our solution can provide 5 Gbps wire speed processing capability.
https://hal.inria.fr/hal-01404003 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, November 28, 2016 - 11:27:44 AM Last modification on : Thursday, March 5, 2020 - 4:47:12 PM Long-term archiving on: : Monday, March 20, 2017 - 7:29:56 PM
